Please help
Is my car fitted with an Interference engine or Non interference engine?i have W168, A class, 1.4auto, 2002, the timing chain has snapped and the car is not moving, i want to know if i the valves and pistons has suffered.
your help would be greatly appreciated
If you have indeed thrown your timing chain then good luck. I hope the damage to your valves was minimal. Why do you ask? Are you looking to rebuilt the engine yourself or just curious at how bad the repair bill is going to get?
Thanks for your response, can i ask what makes you think it is an interference engine? after testing all 4 cylinders found out that there is no compression in any of the cylinders and i am sure the suspect here is the broken timing chain, if the car is fitted with interference engine as you say then it is not worth spending hundreds of £s on it, however if it is a non interference engine then i could have got away with a couple of hundred £,
once again thank you for your feedback
As for fixing it and the cost involved. I wouldn't want to comment on that decision. I'll leave that up to you and your mechanic. However, I would be curious as to what your decision is and what you end up doing with your engine.
Good Luck to you!
