89 jeep Cherokee problems
89 jeep cherokee
Hi, I just am trying to get some insight on my jeep because quite frankly I'm tired of dumping money into it without result. The problems are. It's very hard to start. It will crank and crank but never start. Then when it starts, while at idle or slow speed it will often cut off. It will shake really hard and bog down. The parts I have put on regarding this issue are; ignition coil, fuel pump and strainer, crankshaft position sensor, spark plugs and wires, cap and rotor. I also changed the oil. Please help.
SPONSOR/MBworld Guru
Hi Cody. Welcome to MBWorld.
I'd think you'd get more help at a Jeep specific forum.
You should try posting your question here:
http://www.cherokeeforum.com/
http://www.jeepforum.com/forum/
Good luck
Good luck
