C240 Won't Start
Old Feb 1, 2016 | 11:31 AM
JoeAC2RE's Avatar
Mercedes C240 2004
C240 Won't Start
Hello Everyone,
Newbie here, and I am having trouble.
I have a 2004 C240 that won't Start, cranks but does not fire.
I changed the Plugs.
I installed New Battery.
Not getting a spark at the plug, still looks new.
Gas pressure is good, checked rial.
No codes, used live cranking to test the CPS Cranking RPM is 150 -160, so CPS is good.
Voltage at the coil plug is 12. 8 volts (center pin)
Checked the SAM and all the fuses are good with Ignition in the start position all fuses are showing battery voltage except Fuse #52 which should show voltage upon cranking.
Checked Relay P and its engaging upon cranking.
Any suggestion?
