M272 06 Mercedes e350 serpentine belt question
Old Mar 9, 2018 | 11:03 PM
shawn011274's Avatar
2003 CLK 320
HI guys,
I am new to this site and have a question regarding the serpetine belt and tensioner pulley positioning on w211 M272. I have installed a new belt but the belt hang of the tensioner pulley by 1/8 inch (see pics). Is this normal? I keep realligning the belt but it ends up slightly hanging off the pulley.
Here is where I removed some tension on the pulley and slid the sepertine belt over on tensioner pulley
https://imgur.com/a/cdaHg
Here is what happens after I run the engine for a few minutes
https://imgur.com/a/e9pbV
Is this the normal position, or should the entire belt sit on the pulley and not be off by 2/16 of a inch
After running, it slides over
Old Mar 12, 2018 | 01:24 PM
2003 CLK 320
My apologies
I replaced the entire tensioner pulley assembly, not just the pulley.
Old Mar 12, 2018 | 02:19 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
Replace the engine belt tensioner assembly, not just the pulley.. the pulley alone will solve nothing unless the bearings are failing.. There was a "fix" years ago to shim the tensioners at the front engine cover, but that was just a band-aid in my opinion..
Old Mar 14, 2018 | 04:48 PM
2003 CLK 320
I am done with MB, apparently now I have three additional issues:
1. Oil in the coolant - replaced oiler cooler seals (supposedly need new oil filter housing, cooler and seals)...thats just the start
2. P2006, Intake manifold runner stuck (Have to replace entire manifold - Just lever is a bandaid)
3. Balance shaft showing possible wear - known 4k repair for a car worth 3-5k
* my girlfriends crappy Nissan versa has more miles on it and does require this much expensive maintenance or have these many issues. As a matter of fact i have owned many cars that don't have these type of issues, let a lone luxury cars.
I think I am going to sell the car and stick with my Lexus. Thanks for the help...good luck :-)
