HELP SL R230 with leaking ABC valve pump
Old Mar 14, 2018 | 03:01 PM
bob1995's Avatar
SL 600 R230
Question HELP SL R230 with leaking ABC valve pump
MERCEDES SL600 R230 2004 the rear left hand side ABC valve pump is leaking from the base of the outside casing of valve pump, changed it for another one that was all good installed and started the car, about 20 seconds later a pop cracking sound came from the new valve pump that i just installed and it started leaking again. i also had just replaced the back left hand side shock because the plunger inside the shock was no good, the valve thats leaking is inline and connects to the shock i just replaced. Looking at the leaky valve when i pulled it out to replace it i get the feeling that the base of valve is made to crack open like it has when something not right. There is a lot of info out about the ABC problems but not this problem if anyone can point me in the right direction would be a great help, thank you.
