Trunk on top of top and will not lift up
Old Sep 30, 2018 | 02:29 PM
Michael Moran's Avatar
03 MB sl500
I replaced front hydraulic piston on my top. With the top up, I was not done with job, but done for the day. I lowered the trunk to clear the garage door. Both the top and the trunk moved freely. Back to finish repair next day and the trunk will not lift. Any ideas on how to raise trunk off the top. Thank you.
Old Sep 30, 2018 | 02:31 PM
ItalianJoe1's Avatar
2003 CL 600
Did it clip down into the latches? Not really picturing what you are dealing with here. If the pump is off for a few minutes the pressure releases and you should be able to manually lift the trunk or top open if the latches are released.
