02 s430 air project
Old Jan 14, 2019 | 09:10 PM
Lacmotion1's Avatar
2002 s430
02 s430 air project
Hi every recently bought a s430 with airmatic problems. I will be trying to project stock struts if possible. Does anyone know the fitting size for the air pressure fittings that go on top of the struts? My project is to use the same struts. Possibly change or tap the stock fittings on stock air struts to run after market (thicker) airlines to them that will eventually run to after market tank, compressor, switches and gauges. As of rn the rear level sensor above the axle broke. Just the rod went flying off somehow and now the back won’t air up. So I’m trying to do away with all the leveling sensors and remotely control air. I’ve looked every where and haven’t seen it done so I’ve decided to make a profile and ask myself. Thank you in advance for the advice/ help
-will
