All Electrician help
Old May 7, 2020 | 07:36 PM
James Hewitt's Avatar
S320CDi
URGENT HELP
Can an alternator produce AC and DC current at the same time?
If not then what could be wrong?
Old May 8, 2020 | 09:10 AM
S320CDi
Hi Plutoe,
I know what you are are saying but my question is can an alternator pump out AC and DC at the same time?
Because my cars is.
Old May 8, 2020 | 09:31 AM
dbldpr's Avatar
Veteran: Navy
The alternator does produce three phase AC, but that is rectified to DC to charge the battery. AC is produced in the alternator. It is converted to when a car is running is the current ac or DC. So basically everything in your car is DC. Modern vehicles use an alternator, which is the term used to describe an AC, Current in cars is DC.
Old May 8, 2020 | 04:36 PM
S320CDi
Ok, thanks for your help.
Old Oct 9, 2020 | 05:07 PM
AlisonAlsop's Avatar
Jane
The alternator works with the battery to generate power for the electrical components of a car. An alternator gets its name from the term alternating current. It produces the AC which must be turned into DC to use in a car. A generator handles this internally and mechanically with a commutator and brushes. An alternator pulls off the same trick with externally with electronics. An electricity theme in fact is very difficult for understanding. I always suggest people to call the professional electrician if they have some issues. I can recommend also the platform where you can find the electrician in your area with good reviews. https://bates-electric.com/locations/louisville-ky/
