Air Bag Cod 9183 and 91C3
Old Jan 25, 2021 | 06:24 AM
Ganeswara9's Avatar
American and German Cars
Hi Guys,
Feel free can any one suggest solutions to fix the following fault code for Mercedes E-280, Model 2008, all these appears after I had a minor accident on the left side fender and I had replaced also air bag on right side open, it was replaced as well.
1) fault Code: 9183
The resistance in the ignition circuit containing component R12/1 driver emergency tensioning retractor (ETR/GUS) ignition squib, is too high
2) fault code: 91C3
The resistaresistance in the ignition circuit containing component R12/6 left rear emergency tensioning retractor ignition squib is too high.
3) fault code: 930E
Synchronisation of the DTC memory cannot be ensured
4) fault code: 9062
No CAN message is received from the control module Steering Column Module
5) fault Code: 9069
No CAN message is received from the control module Instrument Cluster
6) fault code: 9060
No CAN message is received from the control module Anti-lock Brake system
7) fault code: 9061
No CAN message is received from the control module Motor Electronics
8) fault code: 9063
No CAN message is received from the control module Electronic Ignition Switch
9) fault code: 9202
Control module A1 (instrument cluster or N73 Electronic Ignition Switch, control module are replaced
10) fault code: 910A
Invalid drive authorization data
I hope to here from you guys, kindly share your experiences on the above.
thank you
Old Jan 25, 2021 | 07:40 AM
speedlimit's Avatar
Administrator Emeritus
Hi,
Welcome to MBWorld!
What model car are you inquiring about? Chassis number and year please, thank you!
Bob
Old Jan 25, 2021 | 07:52 AM
Ganeswara9's Avatar
Thank you for responding,
Mercedes Benz E280, Model 2008
VIN: WDBUF54X18B266291
Old Jan 26, 2021 | 08:09 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the E-Class.
