S-Class (W222) 2014-2020
Replacing Radar Cover
Old Dec 20, 2018 | 11:33 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
Hi all. In 60,000 miles had two unexpected repairs. First was idler pulley that I replaced myself. Second is the radar sensor cover. The chrome lines started to wrinkle as you can see in the pictures. I looked up the grill removal in the service manual and had it out in about 10 min.
Here is some pics. The only one missing is a new cover because I have to go pick it up on a min..
Katie
Old Dec 20, 2018 | 12:43 PM
obwielnls's Avatar
2014 S550
Nice work. My grill has this one tiny little bubble in it.. I'm not going to mess with it until it gets worse just because the grill is pricey.. It was easy to pull out? Just the top two screws?
Old Dec 20, 2018 | 01:46 PM
Katie22's Avatar
There are four screws two have a plastic pop off cover on them. All accessed from top.
After the four screws are removed you must gently pull firmly on the grill at the top out from the front of the car. It will come out about an inch. Thereafter you will see a tab in there on each side of the top this is gently pushed down by a screwdriver. Grill will come out more at top. This would be the time to unhook the two connector wires if you have them.
Next you do the same pulling out at the bottom of the grill. It comes out about an inch and then there are two retaining tabs you push with a long screwdriver.
After grill is out center piece is removed with a screwdriver gently prying on four retainers from the back side of the grill.
Old Dec 20, 2018 | 08:26 PM
Katie22's Avatar
Finished job
Here is the finished new cover on the car. It was not cheap being $319.00 but such is life. For some reason or another the colors dont match in the picture but in real life its all good.
Old Aug 10, 2019 | 06:23 PM
killawatt's Avatar
S550
Was that the cost of the cover? Wow!!! Was it a cosmetic issue or were you having issues with the system
Old Aug 10, 2019 | 07:42 PM
Katie22's Avatar
Just cosmetic. We like to tAke the car to car shows so we try to keep it nice. If I could have fixed it I would have but could not. The corer was around 300 dollars.
Old Apr 29, 2023 | 08:09 PM
rickyc704's Avatar
s550 coupe
Cable next to the camera cable
can anyone tell me what that cable is hanging next to to brown camera cable? Its like a purplish with yellowish
Katie
Old Apr 29, 2023 | 08:19 PM
Katie22's Avatar
I wish I could tell you but it’s been so long ago that I can’t remember. Actually I can guess after further thought. One wire was for the camera video feed and the other wire was for the camera cover accuator.
Old Apr 29, 2023 | 08:37 PM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
You can order just the parts you need. Just found out the Chrome Bezel can be ordered without purchasing the entire grill. I have 2 issues, bubbling Chrome and Clear comming off Radar Cover. Rest of grill is fine.
Upper Grille - Part #222-880-10-02-9040 | Mercedes Parts Center
Old Apr 29, 2023 | 08:51 PM
rickyc704's Avatar
s550 coupe
i have an s550 coupe and theres a wire hanging attached to the hood lock just as that purple one, I have no clue where it goes
