to K&N or not to K&N
2017 SL63
I know this has been hashed out, but I am a newbie and after some fresh input.
I have just installed the Kleemann K1 chip&pulley but I did not put the K&N filters in that they supplied.
Seems the jury might still be out on whether they let to much dirt pass. I live in a very dusty environment. What to do???
i'll second the green filter suggestion...previous people who've put on the k&n subsequently developed problems with their MAF sensor, switched to green filter and boom...no more problems
Green filters are basically the same as K&N with reportedly less oil.
I just put the green filters in the car and it def. breaths deeper and has a nicer sound. Much of this may be because the filter I replaced was horribly clogged up. As soon as I made the change the car started to bite harder easily breaking the tires
so far so good.
so far so good.
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Green or OEM
Go with green filters or stock OEM, but I would stay away from the K&N's Benz-wise at least. HP increase from stock is negligible...only difference is aurally, regardless of what ANYBODY tells you.
98 Black C43 , 12’ ML 350 Blutec
Originally Posted by StapleGun
Go with green filters or stock OEM, but I would stay away from the K&N's Benz-wise at least. .
Come on now....
Aww come on C43AMG....only prior experience what else? You've seen my previous posts, esp applicable to the C43
Originally Posted by FAST FRED
I am new to the M-B family,
What are the green filters you are talking about ? I have a '06 C55 AMG
Thanks,
Fred
Thanks,
Fred
http://www.euroteckmotorsports.com/i...465&product=82
and a detailed how to install on: http://www.euroteckmotorsports.com/i...owse&pageid=84
I read in another forum an opinion that K&N does let in more dirt and is ok only if you don't mind rebuilding your motor every 30k miles. Now I nervous since I just switched to K&N and definitely do NOT want to develop engine problems.
