compressor engine install a blow off valve?
he is asking some Question.....
can the compressor engine install a blow off valve?
becos he like the sound "pshhh"!!!
hope someone can give me a Answer.
thanks
so can it install a blowoff valve in kleemann s/c?
Erik
HLG
Erik
HLG
www.maxima.org has a section in the forum for S/C & T/C cars. The Stillen Supercharger kit actually comes with a standard BOV but most people replace it with an aftermarket one:
Here is a thread with the included parts:
http://forums.maxima.org/showpost.ph...05&postcount=5
"(1) Blow Off Valve Assembly with adapter 407000-24, -8 "
Here is a thread with some pics:
http://forums.maxima.org/showthread....light=pictures
But if you search I'm sure you will find 50 or so different SC cars with BOV, it's not uncommon.
Erik
HLG
do u know any aftermarket centrifugal supercharger kit?
http://www.vortechsuperchargers.com/
I had two bypass valves on my old 99 SOHC Vortech blown mustang, with air/air intercooler. a 1.5 dia ID bolt on bypass across the intercooler and a bosch bypass across the supercharger. It had 375RWHP on 91 octane, with an automatic and high stall converter.
Most belt driven superchargers use a bypass, for when the throttle plate is suddenly slammed shut when under high boost. The air has to have some place to go.
Some food for thought. Swapping the CBV for a BOV in the evo caused alot of problems for people with stock electroincs and MAFs. The system anticipates via software an air dump into the intake via the CBV when the throttle is lifted. It richens up the mixture in anticipation of that air being rapidly recompressed from where it was dumped, then back into the turbo. People who didn't suitably change their ecus would foul spark plugs constantly.
