need advice on M111k cams upgrade
Not very familiar with you engine but i'm running a set of cams myself for an E55 application and can tell you my following experiences.
The 10-15hp sounds about right. Although for my application it's 15-20hp.
The valve reatainer and springs are still stock after the upgrade.
Driveability is not an issue for me (traction is
) but i did notice a much stronger pull from mid to high rpm range. Almost like a freight train.The idle is a bit rough but hardly noticeable imo.
I think it you have the $$$ it's an awsome upgrade. Post pics of the cams when you get them! Good luck!
