Spark Plugs
please explain this one!
as for wires, they produce NO hp. the only reason you might see a hp gain is if your old wires were so ****ed up that a new set actually returned the hp to original figures. the only way to produce hp is to burn more gas/air per stroke.
ok the wire only transmits the amount of energy the coil produces, and actually it transmits less than the coil produces due to resistance. how do the wires keep the exhaust cleaner???
Maybe this will help you NGK
I switched to SplitFire (non platinum) and I gained 2 tenths back.
well switching to new plugs at anytime will give you 2/10
Frequently Asked Questions
Q: How much of a performance improvement can I expect from changing plugs?
A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Where's Vadim when we need him. Maybe, you should do your homework too by checking out www.evosport.com.
