K&N effects on gas mileage and MAF damage
however, he did recommend green filters which i will be getting very soon along with a renntech airbox
When I got my E320 W210 wagon about 2 1/2 years ago, I thought I might save some money by getting a K&N reusable air filter. I check my mileage every tankful (the old way). Over a period of a couple of months I saw my around town mileage go from 18.5-19.0 to 16.0-17.5. I pulled the K&N, cleaned the MAF sensor, installed an OEM paper filter and the mileage improved on the very next tankful. Bosch will point out that the more porous K&N will allow particles which will actually pit the surface of the sensor. This will eventually cause enough damage that the MAF sensor will need to be replaced.
But I understand many people want to have fun with their car and gas mileage and replacement costs aren't very high on the priority list.
Anecdotal data is what it is but over the past several years I have read many posts regarding cleaning MAF sensors in these engines in which the results were successful. One point may need mentioning. You must remove the insert in order to clean the sensor. And, of course, some people may have cleaned temp resistor thinking that was the MAF sensor.
See attached Bosch Document, pg. 3-4 Type HFM-5
