Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Need help on sensor Identification
Old Oct 17, 2007 | 10:59 PM
stallion8797's Avatar
I have a slk320 engine, I need to know what type of crank and cam sensors I have.
If you can point me in the right direction I'd appreciate it.
Thank you.
Old Oct 18, 2007 | 07:55 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Sensors
The cams sensor is on the right cylinder head on the front ( easy to get to), The crank sensor is on the left rear on The flywheel bell housing ( to even see) Cheers ___PTE___
Old Oct 18, 2007 | 06:47 PM
Do you know if they are haltek or mag?
Old Oct 23, 2007 | 10:10 PM
PTE's Avatar
PTE
Sensors
The Cam & Crankshaft position sensors are a 3 wire Hall effect type. The Crankshaft is on the left side , behind the cylinder head mounted on the top of the flywheel bellhousing, and is some what difficult to see. ___PTE___
