Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Auto Tap or AutoEnginuity
Rating: Thread Rating: 6 votes, 5.00 average.
Old Oct 9, 2008 | 06:06 PM
Sysopz's Avatar
'15 CLS63 sAMG, '91 GMC Syclone, '89 Saleen Mustang Turbo Intercooled
I am buying one of the below OBD II Scan/Log tools;
Auto Tap
http://www.autotap.com/product_family.asp?FamilyId=260
AutoEnginuity
http://www.autoenginuity.com/products-scantoolpc.html
Does anyone have any thoughts on what would be the better purchase?
Thanks in advance.
Old Jan 24, 2011 | 12:33 PM
pelletman's Avatar
2004 E500
Auto Tap
AutoEnginuity
Thanks in advance.
What did you buy? How do you like it? Thanks!
Old Jan 24, 2011 | 06:45 PM
ohlord's Avatar
The OP has not posted
in a few years, might have moved on.
What are your plans for either?
You won't be able to change car settings with either.
You can read live data and freeze frame data with both.
I have used the autotap and it is a great unit when used with a notebook or laptop and great support if you need it. Go with the auto tap less money and if you know what you are looking at you won't need the add on software.
If all you are looking for is a good obd2 scanner read codes erase I/M status freeze frame data you can pick up a 59buck scanner at harborfreight tools get 20% off coupon out of field and stream mag and save even more.
Old Jan 24, 2011 | 06:58 PM
pelletman's Avatar
2004 E500
I'd like to be able to fix any problems I run across and do routine maintenance
Old Jan 24, 2011 | 07:16 PM
ohlord's Avatar
The harbor freight unit will
read codes,clear codes,read I/M,freeze data,read o2 data.
That should take care of your needs. If it goes beyond that you probably would need to get it on a sds machine and those are thousands to tens of thousands.
Your M113 engine is easy enough to maintain. It is due for spark plugs,if over 100k miles due for o2 sensors,due for trans fluid and filter change. All within your ability if you follow directions.
need a link to the maint. check off list?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
