Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
easy M103.983 upgrade
Old Nov 20, 2008 | 11:44 AM
Dievs2's Avatar
w124
hey, i'm looking for easy and cheap way to add some horses for m103 engine. maybe modify injection system, better injectors, bigger fuel pump... don't know.
i'm beginer at motorsport and i'm planing to start from w201 with 3.0 12v m103 engine, 5 speed mechanical, low speed reducing gear 3.64 or 3.91, ceramic clutch, stiff and low chassis and big brakes...
can you help me?
Old Nov 20, 2008 | 01:42 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
The injection system is fine. I would install new injectors and make sure there are no vacuum leaks. Set the lambda up on the rich side. This will help when on full throttle contact. The only other thing is ignition timing. There are many different timing maps for different ezls. I would probably suggest a stand alone ignition module for getting a tuning map. Getting timing up into the 22-24 degree range at top end really wakes these up. Also if you are looking for top end power the exhaust is pretty restrictive. New headers and down pipes and catalyst. Get rid of the resonator and new muffler. Better air filter box also.
