Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Who here can recommend an ECU Tuner?
Old Mar 13, 2003 | 10:30 PM
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
Originally posted by Tezta
A stripper once said that to me.
I think that we "played" with the same stripper. Or maybe that's what they learn to say in College.
Old Mar 14, 2003 | 02:56 AM
tango's Avatar
maybe you boys taught eachother!!
Old Mar 14, 2003 | 11:20 PM
BenzoAMGpower's Avatar
Cars and boats!
I just had my DME (ECU) upgraded from RENNtech and let me tell you....it was well worth the money spent. I feel the throttle a lot more responsive, the car reving a bit faster, shift points a bit higher, and staying in the powerband longer. Doing the ECU upgrade really woke up my ML55s restricted motor. I highly recommend this...you wont regret it... I am taking my cousins C32 to do the same!!!
Old Mar 15, 2003 | 11:10 PM
nukblazi's Avatar
Originally posted by Timster
I won't go down alone!
LOL
I haven't modified my ECU.
But it's nice to know that there are people on this forum that like to point fingers and offer information to Government officals.
I think it's time to re-think the value of sharing information.
Tim
huh, what? Someone help a brotha from NJ out, what is all this gov. official, turning in shiet? Aren't there special provisions for modified vehicals?
Old Mar 18, 2003 | 06:20 PM
Lucas's Avatar
Benzmac
I have to corect you a little , We can read the ECU as an open
book, when the mapping is at R/D level with an unknown ECU there is only 1 way to go and that is to try and pull 1 mask after the other, sooner or later the ignition MAP will be found, fuel MAP, torque MAP, V-MAX, ect.ect.
When R/D is done, we will know exactly what we are programing and why we do it.
Only problem, is that the car manufactors " restack " the files on the chip, this is why the ECU have different software versions, so
if we find the V-max on p. 20 in 1 version at can be on p. 99 in the next we do and on p. 30 in the next ect.ect. so to find many cars with the same software version is rare.
When the files are modified, the " CHECK SUM " will change and has to be calculated back within a certan tolerance, if the check sum is out of tolerance, the car can't start.
The top of the line emolators, will automatically calculate the check sum.
Old Mar 18, 2003 | 08:05 PM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Thumbs up
Lucas, knowledge is power.
Old Mar 18, 2003 | 08:45 PM
  #32
benzmac's Avatar
1999 ML 430, BMW R1100s
I fully understand this. I have a hot air station, E-prom reader/writer and soldering station. I have been messing with chips for a while now. There is a company that has cracked the ME controller codes for the BMW cars, but none of them know anything about Mercedes.
I think the only people that know Mercedes chips are AMG and Mercedes Corp.
There are reasons for this....The tuner market is JUST NOW starting to take off for Mercedes. 5 years ago people would laugh in your face if you told them you were starting a business performing high performance work on Mercedes. Times are now changing. There are people out there who see the potential of cracking the Mercedes source code in the ECU and being able to manipulate it for performance gains.
This will take time because of the 1,000's of maps in the ECU's and because, as you said, the maps are not in the same place. Mercedes actually changes the addresses of the maps on a regular basis.
Now, back to the source of this....Renntech probably sends the code to an engineer at AMG who has an "open book" to the codes. This way the source stays protected and Renntech gets what they want.
BTW.....This is just an opinion.
Old Mar 19, 2003 | 01:33 AM
  #33
Lucas's Avatar
Benzmac.
Lots of people know how to program a MB ECU, in basic it's excatly the same as any other car brand with a Bosch / siemens
ECU.
If you can program a BMW, you can program a MB as well. The MB files seems always to be much more difficult to work with than other cars, so most give up.
AMG are not working with Renntech on this and they do for sure not e-mail data any where, all data of an AMG car can be found in the " Vordefinerte string codes ". Renntech are 99 % sure e-mailing their files to MKB or a related chip tuner in Germany.
Renntech don't send codes, they send the HEX file, string codes
and chip re-programing are two different things.
5 years ago the MB tuning market was huge, maybe not in the US
but Europe and Asia, so there is nothing new under the sun.
All the chip gear you have is OK, you cant use it for anything untill
you have the Emolator with the software and check sum calculation.
Old Mar 19, 2003 | 08:57 PM
  #34
benzmac's Avatar
Thanks for translating what I said into german or danish and then traslating it back to english and just repeating what I said.
Point?? I agree on how it is done, but how can others break into this>? That is the question.
Old Mar 20, 2003 | 02:51 PM
  #35
Lucas's Avatar
No problem, you can buy all the gear for it you want, search the net and several companies like EVC in Germany, Giovanni in Italy
ect. ect. invest 10-15.000,00 $ in gear and then start playing.
Good luck
Old Mar 27, 2003 | 01:07 AM
  #36
E55AMG99's Avatar
1951 Caterpiller D6
The guys at TW Motorsports in Campbell, CA shipped my ECU out for reprogramming. The car has more mid-range punch and higher shift points. It "feels" like 30HP and G-Tech says my 0-60 times dropped over a tenth, 2 if the motor is cool. the 155MPH speed limit is gone too. This was confirmed on highway 280 near Woodside one night.
Old Mar 27, 2003 | 08:56 AM
  #37
Pffelan's Avatar
CLK 430 Coupe + MGF + 1980 Camaro
i appreciate all the info on the chips in this thread... but for us non technicals who just want the bloody thing to go faster....
who is the best person to send the ecu to in the u.s and in europe?
Old Mar 27, 2003 | 09:42 AM
  #38
Timster's Avatar
2011 GL450
How much? And how long did it take?
Tim
Old Mar 27, 2003 | 10:08 AM
  #39
E55AMG99's Avatar
1951 Caterpiller D6
It took about 3 days and cost $1,000.
Old Mar 27, 2003 | 10:21 AM
  #40
Timster's Avatar
2011 GL450
Thanks for the info!
Tim
Old Mar 27, 2003 | 11:21 AM
  #41
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
E55AMG, can you provide a phone # for TW Motorsports? And what year model is the car you had modified?
Old Mar 27, 2003 | 07:36 PM
  #42
E55AMG99's Avatar
1951 Caterpiller D6
It was a 1999. T-W Motorsports 2250 Winchester Boulevard
Campbell, CA 95008 - 408-379-0300 Tell them "Greg" sent you.
Old Mar 27, 2003 | 11:03 PM
  #43
Mach430's Avatar
Tim, we actually had Powerchips at our shop the other day, tuning a M5 with us. They seem to be the real deal. They are going to make custom software for my car, and can do the same for you when you come down for your checkup. Let's talk offline about this later.
Ben
Old Mar 27, 2003 | 11:49 PM
  #44
Timster's Avatar
2011 GL450
Sounds very interesting!
You have mail.
Tim
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
