Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
cheap 10hp perfomance upgrade!
Old Apr 21, 2003 | 06:51 PM
Autostream's Avatar
1995 Ferrari Spider, Porsche 911 Turbo,01 Hayabusa, 01- E55
I rememeber a thread a while back about someone saying that they put reflective tape onto the underside of the airbox to reflect the engine heat away somewhat. And that it reduced the incoming air temp. which as a result make the air more dense, denser air will ulitmately give more hp, etc ,etc.
well i tried this experiment and it cost me $10. I made a video charting my impromptu experiment. i know it very unscientific but it looks promising and you have nothing to lose.
both ways show 9 degree increase, yet with the tape, the air was always about 20 degrees colder.
ps. yes i know it wasnt moving so incoming air would be cooler, but it goes to show the heat soak versus reflectability aspect nonetheless. either way i had fun doing it :-)
http://161.58.248.45/images/video/e55intake.mpg
Old Apr 21, 2003 | 08:08 PM
Turbo]['s Avatar
98 E430
BTW: is that the palm OS program that reads the ECU?
Old Apr 22, 2003 | 03:53 PM
speedybenz's Avatar
AMG C43, 1999
I am sorry I could not read the air temps from your Video, could you post the numbers?
Also if you make some Phenolic insulation spacers to be placed between the intake manifold and the cylinder head you will see some very large drops in air temps.
My C280 went from having the manifold too hot to touch after a hard drive to being able to hold your hand down on the warm manifold after the phenolic spacers. My infared temp gun showed temps drops of from 30-40 degrees F.
I guess I need to do both methods on my C43.
Jeff
Old Apr 22, 2003 | 07:31 PM
230KBenz's Avatar
'03 C230K
thats a good idea im gona try it
Old Apr 22, 2003 | 08:56 PM
shaneb's Avatar
Yes what software is that ???
Old Apr 22, 2003 | 09:14 PM
Turbo]['s Avatar
98 E430
How thick are these spacers? And where can you find them at?
Old Apr 22, 2003 | 09:18 PM
nukblazi's Avatar
I really hate to be a pest but I can't view video's because I use a linux machine. Any chance you could grab some of the key stills and do a small write up?
What kind of tape? Thermal or reflective?
Old Apr 22, 2003 | 09:50 PM
jpb5151's Avatar
It plays just fine over here (Slackware 9), using mplayer ( http://www.mplayerhq.hu/homepage/design6/dload.html ). hth
Old Apr 23, 2003 | 01:27 AM
Autostream's Avatar
itll read any ecu on any car imported into us since 96.
i got it mostly to read what the check engine light meant, and reset it. i'll take more pics tom and post info
Old Apr 23, 2003 | 01:46 AM
levelr123g's Avatar
www.autotap.com
Old Apr 24, 2003 | 11:35 PM
nukblazi's Avatar
thanks... I need a small footprint (166mhz 48m ram) Redhat 4.2 (upgraded almost completely through redhat 7 rpms + src. Still using Kern 2.2.x though. All other video players have brought this little laptop to it's knees.
It's like a marriage though, I have had this machine since 97' and I just can't dump it.
Edit-- needs gcc3
Old Apr 25, 2003 | 01:18 AM
Autostream's Avatar
i got a lot of interest in the OBII reader so I put up some pics at
http://161.58.248.45/cgi-local/ultim...c;f=3;t=000061
And its from Auterra, only about $200
More importantly, no one has addressed the pith of this thread. Does it look like it makes sense and helps out with hp improvement?
Old Apr 25, 2003 | 01:50 PM
shaneb's Avatar
My thermo shiled came yesterday ...
I will install that and my k&n filters ....
Stopping heat is almost always a good thing .....
Shane
Old Apr 28, 2003 | 04:22 PM
shaneb's Avatar
I installed my k&n s and the heat shield on the botton of the air box.
The air box no longer gets hot, seems to work ....
We will find out when I go back to the track ....
Shane
Old May 17, 2003 | 11:41 PM
EPower's Avatar
'05 E55
Completed today on my E500. Easy to do. Pics at the below thread.
https://mbworld.org/forums/showthrea...threadid=39709
Old May 18, 2003 | 12:11 AM
Buellwinkle's Avatar
Also check out www.obd2.com (for the palm) and www.odb-2.com (for the PC, the software I use).
Old May 19, 2003 | 02:58 PM
tjcMBE55AMG's Avatar
2002 MB E55 AMG
shaneb -
You have a PM.
TJC
