Crank Yankers
1997 E420
Blown
The Blower is actually a better way to go. You can get the torque and power with moderate boost and mild camshafts/headwork. That way, the driveability wont be to bad. When you go normally aspirated, you have to go radical headwork and valve timing. Driveability sucks, no vacuum, no smog etc. (and actually similar money) an example from chevy: GM crate 502 CI 602 HP motor $16K, a Good 383 small block with a small blower and 7psi, 575 HP under $10K (way under)
AMG C43, 1999
kennygss,
Your statements might have been ture even 5 years ago, but now days those sorts of issues do not exist on a well engineered engine package.
Again the Engine Masters Challange was for NA motors of 365CI and ran on pump gas. The top ten motors had very smooth powerbands and the winner made 608Hp from 365CI, not 502CI.
The engines were judged by the power they made from 2500 rpm to 6500 rpm(?). Not just peak Hp numbers.
Jeff
Jeff
Originally posted by speedybenz
kennygss,
Jeff
kennygss,
Jeff
But to answer your original question... no, we did not consider going with a NA block b/c it would not have made any sense.
#32
1997 E420
Jeff, no argument here on the pwerband etc. What Im saying is that those types of combos are fairly un-streetable for a host of reasons. Mostly radical valve timing issues. Low end vacuum etc. IMO only, the blower route is the easiest, most reliable, effecient , and emission freindly (if thats an issue in this application) way to get the power. The average WInston - cup motor in the 355 CI range makes in the 700 - 750 HP range. Incredable RPM, powerband, peak HP and torque. Incredible reliability considering the application. Totally undriveable in a "street" situation. You want power, but need A/C, P/B, P/S and a warranty: "injection is nice, but I'd rather be blown"
#33
AMG C43, 1999
kennygss,
These motors had very streetable powerbands as smooth as any Mercedes motor.
Sleestack, I guess the point to take from this is that 650Hp from 6.3 liters is sort of a low output with a supercharger. Hopefully the Kleemann supercharger ( which I am well informed of ) will result in Hp out of 750 to 800 hp in a very streetable package that maintains reliability. I am sure Vadim will do his level best.
Jeff
Jeff
#34
Volvo V90 CC
sleestack, I still admire your patience, I remember about 2 months ago you showed us the engine block, congratulations on the crankshaft, I'm sure it will be a killer, can't wait to see dyno numbers
#35
Jeff
Jeff
#36
Originally posted by Dr Chill
Sleestack, are you going to call it a CLK63 Kompressor?
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
#37
#39
I am still very curious as to the transmission and rearend modifications.
Are you going to run the stock transmission, upgrade to a V12 tranny or something else?
Has anyone ever put that type of HP and TQ through an adaptive MB transmission?
I personnaly hate the MB adaptive trannies and would love to convert to a 6 speed. It would be cheaper to buy a new M5 though.
#40
#41
Sleestack I loved your car from the very start, when you first showed us the pics of it! Looked soo aggresive and was even modified to look as hard as it went! Am so excited to see your new creation once you've finished creating it:P On a side note you must have ALOT of cash to spend, because if im right when you first showed us your car it had kleemen v8 sc in it? And now you have gone and done all this?! The line between passion and obsession is thin, which are you?
*after reading this I know it may seem as if it is attacking you but it isnt, just curious. I love your work*
*end obsession*
*end obsession*
