what inputs are required to run 722.6?
Thanks in Advance.
here Is the build: http://www.slkworld.com/performance-...l-v8-swap.html
the 722.6 on pre-05 cars uses the crankshaft position sensor, camshaft position sensor, throttle position sensor and throttle body. In other words, if using a 722.6 in something else, or with a standalone engine setup, you will need these items plugged in for the transmission to work properly.
