best Air filter? s500
what's this ITG brand? I can't seem to find the right application for my w211.
I would not feel the need to run out and replace the K&N's you already have.
I can't use K&N I have them taken out. all w140 s500 don't use K&N oil based filters because they distroy the engine. k&n are good filters just not for my car.
Unfortunately, the oiling seems to make the maf fail prematurely.
It could be that there is a good balance between enough oil to filter properly, and not too much so that it gums up the maf...
But, the oiled type filters have a bad rep from dealers, and some people have gotten warranty repairs refused because they used the filter.
If you are out of warranty, and are careful, I think they can be fine, but in warranty, I don't think it's a good gamble, unless you clear it with your dealer first.
Greg
There is a way to clean the MAF if it gets guncked up. Again you have to be careful and know what you are doing.
If you talk to you dealer just make sure you get everything they say in writing.
ITG are good also, but use oil type product.
You know you could forget all this stuff and get better performance with a carbon fiber intake box. Renntech has a great product.
"The filtering material is composed of a special cotton gauze soaked with low-viscosity oil to give you the best air permeability."
OK, in the same category as K&N...
Back to paper filters.
Greg
so in other words there are no performance air filters that are good for our mercedes benz except for the stock one?
Best thing to do though would be to test the inches of lift with the stock filter vs. aftermarket filters to get a true measure of how well they flow.
If you use an oiled filter, just be careful.
My comments were based on the original poster's comments about how to tell what is enough oil.
If it's too difficult, then don't do it.
Greg
I just got the HiPerformance chip which I would recommend to everyone. anyways It is recommended I get a high performance air filter. Is there any high performance paper air filters? Is there any kind of air filter that fits the w140 mercedes and does not need to be oiled that could ruin the sensor?
- 27-35 more HP and 30-40 more Torque Ft/lb
- Great acceleration at low RPM (1000-2000)
- Sharpens the throttle response much better than stock. More punching power in 2000-3000 RPM range and up.
- Removes Top Speed Limiter/Governor
- Removes the Upshift Delay during drive on cold start
- Smooth Idle
