Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
resonator removal
Old Jun 5, 2004 | 02:13 AM
pointman's Avatar
a car that can't do the throttle reset.
resonator removal
any negatives? still passes emissions? thanks
Old Jun 5, 2004 | 10:28 AM
430's Avatar
430
SLK32
No problems with emissions. You will have more noise which may or may not be a bad thing.
Old Jun 5, 2004 | 03:15 PM
AznxKCBoy's Avatar
2004 Mercedes Benz CLK 500
will it hurt the car over the long/short run removing the resonator?
Old Jun 5, 2004 | 03:23 PM
pointman's Avatar
no.
Old Jun 5, 2004 | 03:25 PM
pointman's Avatar
thanks 430, i asked cause ive already done it, but have emissions coming up...wanted to know if i needed to put it back on. according to my friend i do... i didnt believe him, thats why im checking with the forum. appreciate the help!
Old Jun 5, 2004 | 03:32 PM
AznxKCBoy's Avatar
ahopeter, how much more louder is the car after removing the resonator?
Old Jun 5, 2004 | 03:33 PM
pointman's Avatar
with your v8...its gonna give it a more of a rumble... american muscle car-ish..BUT not nearly as loud or obnoxious... sounds great in my opinion.
Old Jun 5, 2004 | 05:21 PM
430's Avatar
430
SLK32
Smart move not believeing your friend. The resonator is really just a muffler, a perforated tube with something to act as a sound absorber.
Old Jun 5, 2004 | 07:44 PM
s0vietbenz's Avatar
1995 w140 s500
does it give more horsepower?
Old Jun 5, 2004 | 11:23 PM
pointman's Avatar
nothing better than mbworld support.
Old Jun 6, 2004 | 07:58 PM
430's Avatar
430
SLK32
Depending on your car and other modifications you may see a couple of HP and you will loose a good bit of weight.
Old Jun 7, 2004 | 08:53 AM
s0vietbenz's Avatar
1995 w140 s500
will it rumble like a peice of crap ford?
Old Jun 7, 2004 | 11:18 AM
Greg Elmassian's Avatar
2003 SL
I don't like "loose weight", it makes rattles!
I think the weight saving will be insignificant.
You might not gain horsepower, sometimes a change in back pressure can make things worse.... not always, but it has happened.
Anyway, the horsepower change should also be insignificant.
Greg
Old Jun 7, 2004 | 12:46 PM
430's Avatar
430
SLK32
Greg
Yes, there was an extra O up there. Loose is never good.
If I remember correctly the resonator was surpsingly heavy.
Old Jun 7, 2004 | 01:32 PM
pointman's Avatar
change in backpressure usually results in a little loss off the line, but better response high end.
Old Jun 7, 2004 | 02:34 PM
AznxKCBoy's Avatar
hmm kinda confused now. So is it a bad/good thing to remove resonator? or it really doesnt matter removing or not?
Old Jun 7, 2004 | 04:59 PM
pointman's Avatar
good... louder, less backpressure (high end), less restriction
bad..... louder, less backpressure (low end)
depends on what you want to have happen.
Old Jun 9, 2004 | 01:43 PM
I1 ULOOZ
Guest
Posts: n/a
no problems for me so far I like it!
Old Jun 5, 2019 | 11:32 AM
zeroroadkill's Avatar
X166
x166 resonator delete question
2015 GL550
Would like to delete the resonator to get a bit more sound out of this big air pump. All I hear is rushing air (slightly open tailgate with cargo too big to fit) WOT=Wooooosh, no growl!
I have read a lot of threads on resonator delete on several MBZ models. Has anyone done the resonator delete on a X166? If so, does it "drown" at highway speeds?
Made this mistake with a v6 & Flowmaster setup, BAD...
Just want to make sure it will still be quiet at cruising speeds (10-80mph)??? Just bark more at WOT?
HAS ANYONE DONE A RESONATOR DELETE ON A X166 GL550?
experienced advice appreciated
Old Oct 3, 2019 | 02:34 PM
X166
Did you remove an X166 GL550 resonator?
Old Apr 12, 2020 | 11:57 PM
Do_Dirty's Avatar
2012 cls550
If you want more sound, remove the resonator(s). There may be more than one, the more you remove, the louder it gets.
You won’t feel any difference in terms of power.
Old Jun 28, 2020 | 04:41 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
I have a CLK 500 with M113. I looked at a sport muffler, but fitment was a pain, so I swapped in a Vibrant performance resonator. It worked great. Yes a little louder, but it sounds WAY better, and no drone.
Best $50 ever. https://smile.amazon.com/Vibrant-Per...TPI/ref=sr_1_4
