Supercharging VS Turbocharging Pros and Cons?
Supercharging or turbocharging your MERC.
I'm new to this forum, so I was interested to know who has done either, which one is more reliable, advanced, cost efficient, the MOST POWERFUL?
IF there are some experts in this forum, I'd really appreciate your input.
Sorry, if I'm repeating somthing you guys may have already talked about, but it would be nice to revisit it again,
Thanks.
Nighttrain.
Btw, the 55 puts out 530+ HP.
am i right BEN?
...... i hope i'm right.
A centerfugal SC will not produce this kind of linear boost- ever. Its is a gear driven turbo compressor- the worst of both worlds. The drive ystem cannot spin the turbo impeller at the speeds it is most effective. These are the SC's that provide boost that generally increases with engine speed.
For pure power, the turbo is the absolute king. Of the energy released during the combustion process, 1/3 is absorbed into the cooling system, 1/3 is absorbed down the the crank (power), and the remaining 1/3 is expelled (wasted) as heat out of the exhaust system...herein lies the turbo's advantage: using normally wasted energy to power a fan and ultimately reroute huge amounts of air for increased power/torque, whereas the supercharger drains power from the 1/3 absorbed down the crank, and cannot take advantage of wasted exhaust energy. Turbo lag is definitely a side effect of a turbo system, but is highly overstated as a drawback. Sure a giant T88 driven MKIV Supra will see a significant amount of lag, but the payoff is over 1000HP at the crank and sub 10 second ¼ passes. On the contrary, a well designed medium boost turbo system will outperform any other method of forced induction, while achieving full boost by 3000RPMs. Turbochargers have been responsible for thousands of wins within F1, IRL, LeMans, Rally, etc…don’t think I can remember the last time a supercharged car won a race when faced against other turbocharged vehicles. While the positive displacement blower has gained in popularity with OEMs, it has by no means replaced the turbo…rather it gives OEMs a cheaper alternative for street applications.
We have shown and documented this over the last year in European Car magazine with our project e36 M3 Turbo.
Turbos are the answer for the biggest power, however, in the real world the costs are way too prohibitive to make them a better option then a good S/C like the Kleemann.
Brad
Perhaps at the R&D stage...the finished product only requires some additional CNC plumbing (about $700). The installation labor is approximately the same (about 16hours vs. 20hours). The additional hardware such as a wastegate, BOV, intercooler, exhaust manifolds, and boost controller are only about $2500.
<i>Further, to get extreme power out of a turbo, you must have a turbo specific motor.</i>
Same goes for any method of forced induction...whether you have a supercharger or turbocharger, they are both doing the same thing: stuffing more air into the combustion cylinder. Just as a turbo engine requires low-compression ratios too incorporate boost figures over 0.8bar (about 8.5:1-9.3:1), so too does a supercharged engine.
<i>Turbos are the answer for the biggest power, however, in the real world the costs are way too prohibitive to make them a better option then a good S/C like the Kleemann.</i>
Not true at all...there are plenty of V8 turbo kits available for other makes/models priced under $6K capable of 1000+HP...case in point: the Twin Outlaw Mustang 5.0L turbo...$5500. Another example on the other end of the spectrum would be the Koenig twin turbo system for the 360 Modena...about $25,000 for the kit (only about $8K more than the Kleemann55...but still less expensive in terms of car value $80K vs. $200K). Once Mercedes V8 twin turbo kits become available, they should be priced competitively with any other forced induction alternative...there is no reason for them not to be.
Turbo = Better peak HP #'s, TQ ~ ok
S/C = Better TQ : HP ratio
Oh, yeah, and HEAT, very parasitic to usefull power in any engine, let alone forced induction.
Heat make car go BOOM!!!
John.
The only turbo car that might change my mind is the 996 TT, but unfortunately that's out of my price range!
If turbochargers give more power,why is it that almost all professional (Top Fuel, etc) drag racers use supercharging?
I think maybe turbos give more "bang for the buck" - of course NOS is even cheaper...
[BNot true at all...there are plenty of V8 turbo kits available for other makes/models priced under $6K capable of 1000+HP...case in point: the Twin Outlaw Mustang 5.0L turbo...$5500. Another example on the other end of the spectrum would be the Koenig twin turbo system for the 360 Modena...about $25,000 for the kit (only about $8K more than the Kleemann55...but still less expensive in terms of car value $80K vs. $200K). Once Mercedes V8 twin turbo kits become available, they should be priced competitively with any other forced induction alternative...there is no reason for them not to be. [/B]
Show me a twin-turbo Mercedes Kit for $18K that makes as much power and driveablilty and has any reliabilty and costs $1800 to install and I will buy 20 of them on the spot!
Brad
S/C = Better TQ : HP ratio</i>
Completely incorrect...the only supercharger worthy of a comparison is the Lysholm screwtype, with a claimed efficiency rating of about 75%. However, a turbo will always create more HP/Torque due to the fact that it is not a parasitic device (doesn't drain power from the engine) and doesn't create as much heat in the intake charge.
Comparisons between screwtype superchargers and turbochargers:
<u>Aftermarket Kits</u>
<a href="http://www.mbautowerks.com/performance/latest_project.html">MB Kleemann CLK55</a>:
Displacement: 5439cc
Compressor: PD Lysholm Screwtype w/ heat exchanger
Boost: 7psi
Power: 515HP
Torque: 519ft.lbs
Power/liter: 93HP/liter
Torque/liter: 94ft.lbs/liter
Cost: $16,995
Cost/HP: $98/HP
BMW AA Turbo M3 Stage 1
Displacement: 2990cc
Compressor: Intercooled Turbo
Boost: 7psi
Power: 360HP
Torque: 361ft.lbs
Power/liter: 120HP/liter
Torque/liter: 120ft.lbs/liter
Cost: $8,700
Cost/HP: $72/HP
<u>Production Vehicles</u>
Ford Saleen S281-E
Displacement: 4601cc
Boost: 12psi
Power: 425
Torque: 440
HP/liter: 92HP/liter
Torque/liter: 96ft.lbs/liter
Porsche 996 Twin Turbo
Displacement: 3600cc
Boost: 12psi
Power: 415HP
Torque: 400ft.lbs
HP/liter: 115HP/liter
Torque/liter: 111ft.lbs/liter
I think the numbers speak for themselves.
<i>Oh, yeah, and HEAT, very parasitic to usefull power in any engine, let alone forced induction.
</i>
You're absolutely correct...another reason why the turbo is superior and more efficient. While a screwtype can employ a heat exchanger, it is puny in comparison to a single or twin mounted intercooler(s).
jswedberg:
<i>If turbochargers give more power,why is it that almost all professional (Top Fuel, etc) drag racers use supercharging?</i>
There will always be exceptions, however, top fuel racing is a different beast where a race lasts about 4 seconds. In any other form of motorsport => F1, IRL, LeMans, WRC, etc...the turbo is the device of choice (past or present).
Brad:
<i>Sorry, you are right - I thought we were talking about Mercedes, not Ford.</i>
Geez...are we that arrogant? I didn't think you would reply with such an ignorant comment. FYI...the Ford Mustang 5.0L had one of the strongest engines ever produced, with many capable of 1000+HP on stock bottomend. And besides, I wasn't comparing Ford vs. Mercedes, instead I was merely pointing out that a V8 twin turbo kit can be had for less than $6K...meaning that a twin turbo kit for the M113 V8 would not need to cost significantly more...definitely not more than the Kleemann SC.
Boost: 7psi
Power: 515HP
Torque: 519ft.lbs
Cost: $16,995
Cost/HP: $98/HP
Boost: 7psi
Power: 360HP
Torque: 361ft.lbs
Cost: $8,700
Cost/HP: $72/HP
Also, your numbers for the AA are about 10hp off. The gain is really about 100HP, to 350HP. Well, how do we know this, if you look at any issue of European Car over the last 18 months you will see the project car that only we have worked on (built many different stages of the AA Turbo on this car).
So, the real numbers are:
Kleemann - $108.64 per HP gain
AA - $95.45 per HP gain
Still not equal, but if you are going to give specifics, I think we need to be exact - don't you? This is also much closer then your number previously indicated.
However, comparing one Turbo on a BMW and a SC on a Benz is just stupid. There is no way to compare the gains of one type of system on one motor to the gains of another type of system on a different motor. This is just hype and is as worthless as bench racing. There is ZERO scientific or engineering proof gained by this!
Now, if we look at a S/C on the BMW, which we also do, we see the same HP numbers for roughly $2500K less installed and much less heat build up and potential for disaster.
Ford Saleen S281-E
Boost: 12psi
Power: 425
Torque: 440
Boost: 12psi
Power: 415HP
Torque: 400ft.lbs
<i>Oh, yeah, and HEAT, very parasitic to useful power in any engine, let alone forced induction.
</i>
There will always be exceptions, however, top fuel racing is a different beast where a race lasts about 4 seconds. In any other form of motorsport => F1, IRL, LeMans, WRC, etc...the turbo is the device of choice. [/B]
Ever driven those cars? I have - you have HORRIBLE power till it comes on cam, then the cars scream as the turbos spool up. If you never let the revs fall, you will never loose boost.
Now, for the street, most of the RPM range used is much lower. Hence, a SC where the torque and power come in much lower is better suited.
Geez...are we that arrogant? I didn't think you would reply with such an ignorant comment. FYI...the Ford Mustang 5.0L had one of the strongest engines ever produced, with many capable of 1000+HP on stock bottom end. And besides, I wasn't comparing Ford vs. Mercedes, instead I was merely pointing out that a V8 twin turbo kit can be had for less than $6K...meaning that a twin turbo kit for the M113 V8 would not need to cost significantly more...definitely not more than the Kleemann SC. [/B]
Yes, the mustang motor is very strong. So what? Do we have that motor in any MB? I think not. Let's try to talk about the MB motor as that is what the people on this board actually have and are asking about!
The cost of the Mustang kit has nothing to do with a Mercedes kit either. As you said the Ford motor is much stronger then the MB. As such, it is easier to toss a bunch of power in there without other modifications. Also, how many Ford Mustangs are there in the world, how many of those turbo kits do you think there are?
Do the math.
If the R&D costs $100K (which is WAY low) and there are 10K cars that get the kit, the R&D costs will only add $10 to each kit.
If there are only 10 cars that get the kit, the R&D distribution per kit is $10,000.
Which example do you think applies to the Mustang, and which one to the MB? I will let you try to figure that one out on your own!
Brad
The numbers I indicated were taken directly from AA, Saleen, Porsche, and MBAutowerkes...so I feel they are going to report the correct numbers. I'm not going to bother reading the rest of your reply...sorry, I've got better things to do than meddle with you about such things...you have your opinion, I have mine.
Turbos are undoubtedly better adiabatic efficiency wise that any other compressor- period. Its the manner or characteristics of boost production that make the systems different.
Racing eninges will always be turbocharged- they live life in such a narrow RPM band that low speed boost production isnt even the point. F1 engines IDLE at 3K just to stay lit- Its difficult (if not impossible) to have a turbo produce significant boost below 3K engine RPM while making good boost on the top end. A small impeller will spin at low rpms, making boost, but provide prohibitive restriction at higher engine speeds. The opposite is true with a large impeller- NO boost down low and WADS of it up high. VATN (variable area turbine nozzle) turbos provide "two turbos in one" but have their own set of issues. Soon enough these will be solved.
A PD screw type SC provides boost pressure just above idle- if ratio driven properly. They do require power to turn- just as anything would. The amusing thing to me is that many people think that turbos are "penalty free" compressors- BS. Without backpressure the gas velocity required to spin a turbine isnt there. Quantify the hp loss of putting 5.5 liters per rev of spent gas through an opening the size of a half-dollar- less than a PD SC? Yes- Free? No way.
STREET performance- TORQUE is where its at. If you have two engines both making 350hp/300tq peak but one makes peak tq at 2200 and the other at 4200 the first car will out accelerate the second 0-60 EVERYTIME. Porsche ran extensive tests in the mid 80's with the 951 with SC and turbo- result? A sc'd 951 with 2 psi less boost would out accelerate the turbo to 100 mph- so much for big hp.
As for the cost comparision- this makes me *yawn*. If you havent seen a KLEMANN sc you owe it to yourself to look it over. Turbo systems are CHEAP to produce the parts for- they are off the shelf items- bent tubing, existing turbos, intercooler cores etc. EVERY single part of a KLEEMANN sc is cast and unique to our system. Dollar to hp is the talk I always hear- what about qualities like fit and finish- integration into the whole- reliability- serviceability etc.
Why post the War and Peace of posts and then claim not to have time to respond or read a rebuttle to your post? Whatever issues that exist between you, evsport, brad, myself or anyone for that matter shouldnt prevent you from participating in the heated exchange of ideas. You cared enough to make the first post but wont read or reply to the rebuttle?? Whats the matter, cutting into your Grand Turismo time?
<i>STREET performance- TORQUE is where its at. If you have two engines both making 350hp/300tq peak but one makes peak tq at 2200 and the other at 4200 the first car will out accelerate the second 0-60 EVERYTIME.</i>
You are absolutely correct in saying that a PDK will create more low-end torque, but is this necessarily always a good thing especially when dealing with street tires? Smoking the tires off the line is great for show, but I'll gladly suffer a little lag in boost to get out the hole and hit the torque pipe right around 3K. Plus, having a manual transmission mated with a turbo virtually eliminates the PDK's low end torque advantage...allowing the driver to launch the car right at the turbo's torque peak. And while turbo race engines may always live in a narrow RPM band, is this not where the majority of street races are won as well?
I’m not saying the screwtype is the lesser equivalent to the turbo…on the contrary it commands respect as a forced induction device...it's ability to displace large amounts of air at low revolutions, while keeping a high thermal efficiency throughout most of the power range, gives it an obvious advantage in torque production. Secondly, it’s female/male helical blade arrangement allow for a much more efficient compression process as opposed to a twin blade roots. Plus it has only slight drawbacks when compared to other PDKs…namely some efficiency loss at low/high rpms and a slight increase in heat at idle/low throttle due to it's internal CR, which requires more power to run when under low-boost (however, this drawback is alleviated through the use of a heat exchanger). The Lysholm is definitely a superior device when compared to other forms of supercharging and Kleemann’s adept approach to incorporate an efficient air/water intercooler and manifold into one unit, makes it the best supercharger on the market (believe me, I did my homework on this long before I contacted the office in Denmark and would’ve loved to have slapped one on my 55, but unfortunately politics got in the way).
In any case, this topic is highly subjective and can be debated to no end...I tried to offer my perspective on the subject…I apologize if my opinion is somewhat biased in favor of the turbo, but I’m definitely entitled to it. In the end it all comes down to opinions and <i>egos</i>.
My post was static to you as you don't agree with it. I have no problem with that. You are free to think whatever you want.
However, when you come onto a board and post in such an authoritative way using statistic after statistic, even if they are unrelated or inapporiate, you may color people's abilty to understand the issue. This is totally unacceptable to me. We started this board to offer people a means to get accurate and honest information and a healthy debate.
This thread was not started asking about the merits of S/C's and Turbo's on all cars. It was a question on the merits of each for a MB.
If you are unable to answer that question and need to compare BMW's to Mercedes and Mustangs to Porsche's, then I think you are creating far more static then anyone else.
As for your attempts to be civil, I will answer this once and once only - in a personal message. Samir, it is inappropriate to continue to bring this up in a public forum, and we refuse to be dragged into doing so.
Brad
