Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
brake fluid
Old Sep 17, 2004 | 08:31 PM
yellowslk's Avatar
2006 s2000
brake fluid
Im starting to up grade my braking system on my slk and was wondering which dot 4 brake fluid is best.
Need help because im a newbie when it come to brakes.
Old Sep 17, 2004 | 08:47 PM
E55AMG99's Avatar
1951 Caterpiller D6
Castrol SRF is the best DOT 4 but when you see the price you'll probably settle for ATE Super Blue or ATE Type 200.
Old Sep 17, 2004 | 11:44 PM
yellowslk's Avatar
2006 s2000
wow
$85 dollors a liter. That is alot. I guess its only worth it if I go racing with my car.
Old Sep 19, 2004 | 01:09 AM
levelr123g's Avatar
it doesnt really matter, unless your going to be racing then regular dot4 fluid will be more than enough.
Old Sep 19, 2004 | 01:19 AM
yellowslk's Avatar
2006 s2000
ATE Blue stuff
Hey I was wondering if there are any store that carry the blue stuff brake fluid. I dont what to order it on line because it would take to long. I live in Los Angeles.
Help anyone.
Old Sep 19, 2004 | 02:29 AM
speedybenz's Avatar
AMG C43, 1999
The best readliy availible brake fliud is Motul 600. Go to your closest motorcycle shop for some.
Old Sep 19, 2004 | 04:26 AM
awiner's Avatar
2003 CL55 AMG
Motul 600 has much better specs than ATE Super Blue.
Old Sep 19, 2004 | 10:50 PM
nukblazi's Avatar
I am running the motul, I absolutely love it.
Old Sep 20, 2004 | 12:24 AM
awiner's Avatar
2003 CL55 AMG
I'm going to bleed and refill with Motul soon as I am getting close to 2 years.
Old Sep 24, 2004 | 04:28 AM
yellowslk's Avatar
2006 s2000
Thanks everyone.
Just finish my brake up grades. Good new steelbraided lines, Zimmerman vented rotors, ATE Pads for bedding in my rotors. Will switch to PBR went rotors turn green. And Motul 600 brake fluid. Funny thing is that it dosent feel that much better. I got alittle more respones from the brake petal. Maybe it will get better when I put my racing pads in.
Thanks speedybenz for you help. Found the Motul 600 at a honda bike shop. Now also thinking about getting a CBR 600R
Old Sep 26, 2004 | 10:02 PM
nukblazi's Avatar
I went with StopTech slotted rotors, porterfeild r4s pads, motul 600 and stoptech ss lines, my brakes are unbelievably better. Repeated stops from 60 -70 and the brakes smoke but don't fade, pedal feel is very firm even after repeated (5 -8 times) 60-0mph stops and running hard on the curves around here.
With the stock setup, I could push the pedal to the floor, I faded after two 60 -0 stops, and it took significantly longer to get to 0.
Old Sep 27, 2004 | 11:35 PM
yellowslk's Avatar
2006 s2000
MY brakes are bedding in now. And they do feel better. Quicker respones and harder petal feel. Brakes are still fading after 7 stop from 80-5. Hopefully it will get better after I put in some better pads. Im using the ATE for braking in my rotors.
Nukblazi
How long have you have the porterfield r4s pads? Are you getting any warping? Any noise and how are they when you brakes are cold?
Would you recommend them? Have you tired any other racing pads.
Old Nov 5, 2004 | 05:39 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Question from a brake rookie
A question, if I may. If this has been discussed, please let me know and I will delete the post.
I have brake vibration at the front, and the dealer is not very helpful - they definitely are not going to fix this under warranty. So I have decided to put new brake rotors and pads myself and in the process want to install SS brake lines.
Now, the question: when changing the brake lines, do I have to drain all the fluid from the brake system? I believe that no matter what, some old fluid will still remain trapped, so - is it ok to mix it with, say, Motul 600?
Also: how much fluid do I need for this type of job (including bleeding) in this car?
TIA.
