Tuner Shop in SoCal
I’m in the middle of using an 2002 SLK32 AMG as the donor car for a Gullwing replica.
I got a little carried away with system deletes and now the gauge cluster showing the check engine light, along with the ESP/BAS and limp mode.
This just happened and I’m guessing i have a few options.
1) since everything is exposed, i can probably replace the harness from the Transmission control unit to the fuse panel and the shifter. I’m guessing these are available used and maybe new??
2) source a set of wiring diagrams and an OBD reader and see if i can find the source of the problem. Not fun.
3) find a shop that sells chassis harnesses for swaps and ecu programming/ flashing.
thoughts!
thanks in advance
Rex
