Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
Why no "gif" images allowed for sig/avatar
Old Nov 19, 2006 | 11:49 PM
starbrite's Avatar
2004 E320
I've seen others on this forum with gif images in there signature and their avatar but wnen I try to change mine to one I get a msg "you may not upload animated images". ? It's not a post count thing because I've seen others w/equal or less posts w/these gif's.
(same thing w/"html" code in posts-turned "off") Thanks
Old Nov 23, 2006 | 03:25 PM
vraa's Avatar
You can link to .gif images.
You just can't upload them to the server.
So upload it to www.imageshack.us or another hosting utility of your choice, and link to it from there.
Old Nov 23, 2006 | 03:35 PM
starbrite's Avatar
2004 E320
Unfortunately not
Yes, that's true for the body of a message. However it doesn't work for an avatar or signature that I can see. (where you enter a URL to the gif results in the same no can do message.) And if I try to enter a image link directly into the signature box, that doesn't display anything but the text.
What am missing here please ?
Old Nov 24, 2006 | 11:20 PM
starbrite's Avatar
2004 E320
Ok, got the sig to work w/an img code, but still don't see it for an avatar.
Old Nov 25, 2006 | 01:34 AM
vraa's Avatar
Avatar won't work, unless it's resized.
gifs should work for avatars...
Old Nov 25, 2006 | 06:30 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
<---- Working example.
Old Nov 25, 2006 | 10:20 AM
starbrite's Avatar
2004 E320
Thanks to you both, I do understand the resize restriction @ 65x65 and the image I'm trying to use is 64X47 (2KB).
But when I try to save /upload this is the next screen I get:
The second image is the bottom of the signature edit page-notice red circled item re NO gif's. Possibly this is applying to avatars as well ?
Attached Thumbnails Why no &quot;gif&quot; images allowed for sig/avatar-avatar_msg.jpg   Why no &quot;gif&quot; images allowed for sig/avatar-sig.jpg
Old Nov 25, 2006 | 02:59 PM
vraa's Avatar
Those rules listed on the signature page do not apply to the avatars.
You are getting an error message when you upload a properly sized avatar in the avatar section?
Old Nov 25, 2006 | 03:07 PM
starbrite's Avatar
2004 E320
Yes, that is the message in the first image, in the post above, trying to upload a properly sized gif in the avatar section.
Old Nov 27, 2006 | 09:37 PM
vraa's Avatar
I cleared out your avatar settings just in case, effectively reseting that portion of your account.
Try again and let me know what happens, also can you give me the description of the avatar you are trying to upload (pixel size/dimensions as well as kilobyte size?)
Old Nov 27, 2006 | 10:51 PM
starbrite's Avatar
2004 E320
Gif is an American flag 61x45 pixels , 2KB in size ( tried others as well approx the same size.) Still the same message that I "may not upload animated images". Ok, too muich time spent on this already, not a priority at this point so let's just forget it. Thanks anyway.
Edit : maybe the image has to be perfectly rectangular, ie 65X65 ?
