R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R Class Unofficial Pic Thread!!
Old 03-26-2016, 01:53 PM
  #176
vytas85's Avatar
mercedes w251 r class
Originally Posted by marc hanna
Very nice! Is that custom mesh in the front skirt?
thanks.yes front mesh i made myself,just i decide try make one before i spend 300dollars on oem ones
Old 03-26-2016, 10:38 PM
  #177
dinfung's Avatar
2013 R350
Originally Posted by vytas85
r320 with vossen cv3 r22 10.5j tyres 265 35
What offset are you running? And rubbing?
Old 03-27-2016, 05:05 AM
  #178
vytas85's Avatar
it's a straight set all wheels 10.5j offset 42 tyres delinte d8 265 35 r22
Old 03-29-2016, 01:48 AM
  #179
JonMac's Avatar
2002 C240 (W203) 2007 R500 (W251)
Just finally adding my R500 ... had it a couple of weeks now... she's very well optioned but otherwise stock... i've just completed my lighting refit... Lowbeams to HID5k, Highbeams Diamond Vision, City - AznOptics T10 COB, added the little DRL's into the fog spot but not sure about the color and finished off today with the LED star grill... i've got the parts for a reverse camera but haven't tackled that yet and want to refit all interior lights to LED but some of the fittings (ie dome) are just painful to access ...
Old 03-30-2016, 06:30 PM
  #180
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
The domes both front and rear have spring clips. I just use a flat screw driver to catch the lip to release them. For the front you have to remove the rain sensor cover first - squeeze at the top and pivot it down.
Old 03-30-2016, 06:48 PM
  #181
dinfung's Avatar
2013 R350
i been thinking to replace all the interior light to led. anyone try to replace the led bulb behind the door handle?
Old 03-30-2016, 06:49 PM
  #182
JonMac's Avatar
Thanks Marc I've read the threads and I've even got the wis dvd's (three mercs in the household now so I thought it was a cheap investment lol but haven't installed it yet. 70gb! Sheesh...)
I got as far as getting the rain sensor off but then I got stuck I'll try again when I got time to do it without rushing
Old 03-30-2016, 06:57 PM
  #183
marc hanna's Avatar
There's four clips in total - one for each corner basically. The ones closest to the windshield are closely spaced, and the other two are spaced far apart - there's a cut away in the corners that you'll be able to see as you pry it away - this will indicate where the clips are.
Old 04-19-2016, 07:28 PM
  #184
e.pros's Avatar
R350, E320, S550, GLA250
Here's my 2007 r350 with 20" flat black rims and conti tires.
txcls550 (01-16-2024)
Old 04-19-2016, 08:08 PM
  #185
dinfung's Avatar
2013 R350
Look great, are those weather tech windows visor? how do you like them?
Old 04-19-2016, 08:36 PM
  #186
e.pros's Avatar
Yes they are Weather techs. Zero issues at all... looks exactly the same the day I bought it.
  #187
JonMac's Avatar
nice e.pros! ... thinking of blacking out the chrome or you like the lines? Just curious how good a full black would come out
Old 04-20-2016, 12:26 AM
  #188
e.pros's Avatar
I'll keep it as it is for now. Ponying up for a Wald kit... Hopefully completed this year.
Old 05-08-2016, 02:09 PM
  #189
vytas85's Avatar
i got removed my vossen wheels,just got some black Kahn wheels r22 9j all round,plus i use 3m satin matt wrap remove all my chrome surround i think it's looks much better now
dinfung (05-08-2016)
Old 05-08-2016, 06:51 PM
  #190
dinfung's Avatar
2013 R350
wow, it look great. i am planning to plastidip all the chrome on my R also. may i ask what size tire are you running?
Old 05-08-2016, 07:04 PM
  #191
vytas85's Avatar
hi.tyre size 265 35 r22 offset et 35. My original plan was use to plasti dip as well.but after long search i decide remove all my trim and wrap them reason for better finish and long lasting result.
Old 05-08-2016, 07:23 PM
  #192
JonMac's Avatar
gorgeous R tyres are just simply beefy ! And i love the whole blackened look.
am hunting around for 'stock' AMG 21"... no chance to blacken anything, my R is Irridium Silver lol... is your R on Airmatic and did you have to adjust any suspension either way to fit 22's?
thanks!
Old 05-08-2016, 08:09 PM
  #193
taranch's Avatar
BMW 340i xDrive 2018 MMPSK silver , Cadillac XT5 2018 silver, 09 R320 BT
Simply gorgeous! Enjoy!!!
Old 05-09-2016, 02:55 AM
  #194
vytas85's Avatar
thanks!
hi.thank you yes my R on full airmatic,you don't need adjust anything to fit r22,but on my i got lowering links,so i lowered it alot,and r21 amg wheels good choise
Old 05-10-2016, 07:17 PM
  #195
dinfung's Avatar
2013 R350
I have full airmatic also. I have order a lowering module. I am going to try the software way to lower it.
I have a set of 22" Renntech coming. Now i have to decide on tires size and brand. I was going to go with 285 35 22,
Old 06-18-2016, 02:39 PM
  #196
dinfung's Avatar
2013 R350
Finally have the tires mounted and wheel put on, with the airmatic, i don't think the ride is that much different.
nathandimond (08-31-2022)
Old 08-01-2016, 09:58 AM
  #197
MRsedes's Avatar
07 ML 320 CDi, 06 R350L, 07 R63L
Here are some 295/45 R19.
Springs on front, bags at rear.
Old 08-09-2016, 06:49 AM
  #198
MB-R251's Avatar
2011 Mercedes-Benz R550
Hello R-class community,
I have been following this interesting community quite some time, and now I want to show you my 2011 R-Class 5.5 L V8 from Germany, with:
- Carlsson 10 x 22" 1/5 Revo with 265/35R22 front and 295/30R22 rear
- Carlsson C-Tronic lowering module
- Brembo GT kit, 8-piston 34x380 mm front and 4-piston 28x380 mm rear
- Valve-controlled exhaust system with AMG exhaust tips
- Lorinser side skirts + MB front and roof spoilers
and some more goodies.
The following 5 users liked this post by MB-R251:
AsianR350 (08-09-2016), dinfung (09-05-2016), JonMac (08-11-2016), nathandimond (08-31-2022), txcls550 (01-16-2024)
Old 09-05-2016, 03:53 AM
  #199
triggeraa's Avatar
1980 450SL
2006 R500 with 20" Brabus wheels.
Old 09-27-2016, 10:31 PM
  #200
auto385's Avatar
2015 Cadilac Escalade ESV, 2010 MB R350 Diesel
Got my 2010 r350 Bluetec about a month ago. Had winter tires and rims on it. Finally got the right tires and rims. AMG replica rims 20x9.5 with 255/55r20 Pirelli tires. Now the odometer actually shows the right speed and isn't off by 5%. I roadforce balanced them myself since I'm **** and the machine runs like a dream now. I bought this r-class so I would use my 2015 Escalade ESV less, and I tell you what. This Mercedes rides a ton smoother and more comfortable than the caddy. It has about 75k miles on it, but has a ton of life left in it. Nothing nicer than to buy a used vehicle that has been pampered by the previous owner.
Quick Reply: R Class Unofficial Pic Thread!!
