Backup camera installed to factory system, with pics!
Let me know if you have other questions.
The most labor is to fit the camera on the back door. You have to break all the pins that hold the plastic panel. The broken pieces of plastic went in between the metal door panels. I some how broke the electronic lock in that process, it ran none stop, so I had to call the road side server guy over. But again, I have a new lock afterward, just it will last
Ste
How do you "easily" find out if the COMAND is configured for one? We currently have two headrest DVD displays where movies can be played either via middle seat player, or via AUX on the COMAND unit.
Do you know if the Accelevision RVC1100 camera model will integrate? http://www.monstermarketplace.com/Au...574a28333.html
There just don't seem to be any sites that give me the exact MB specifications!
Thanx!
I am assuming I need not do anything on the NAV side, as that should just work....Do I need a Sirius module? If so, anyone got the part# or a source?
Do I need a cable/special connector for the camera? Is it factory run? Or do I just rig one and connect to the pins?
Any help would be appreciated.
Thanks!
How did you remove the trim from the rear tailgate and was it easy to run the video cable through the rubberboot?
Did you then run the cable through the headliner or the floor?
Is it worthwhile to run the cable myself or get an installer to fit it all up?
I picked up one off ebay with CCD sensor and guidelines. It was for the S-Class and we had to shave about 1cm off the base to fit it!
You cant tell we had to mod the base as the chrome trim hides all of it!
The installer also tapped into the 12V cigarette socket for 'accessory power' instead of using the reverse light. (They said that they have seen a poor power supply resulting in a scratchy picture)
I have to return next weekend to pull out the head unit and connect it using the FAKRA E (Green) connector.
When we tested the camera, it looked perfect given its CCD sensor and not CMOS. Its overlay guidelines do not move, but did have a flashing STOP in the closest section.
Could you please post a link to the cam you bought on e-Bay ??
You wrote "you shaved off to make it fit"
Could you please describe in detail ?
I think the R camera also fits in the ML so I could benefit from your tip.
Many thanks in advance,
Grtz,
Nico
I've bought one of those wireless reverse cam that mounts onto the rear number plate. Question is, I can't seem to find a good route through the trim to the reverse light for power. Everything seemed so tightly fit. Can anyone advise how best to unclip the trims? Any fear in breaking them?
Thanks!
Hi Maxxie2,
this is the one i ordered. http://www.ebay.com.au/itm/260745546195
The overlay is different but adequate.
We had to shave the front and back plastic to make it fit, it wasnt hard if youy have a mounted circular grinder handy.
the width 170deg view is ample however i would have like to see further back (but it may just be my mounting angle) The mounted angle lets me just see the edge of my bumper bar, which is the most important thing anyway.
Thanks!
the chrome trim has to be unbolted after removing the interior boot trim.
Not hard, but just have a plastic tool so not to scratch paintwork inside the boot.
If i were you, i'd probably skip using the wireless unit, unless you have to mount a separate screen at the front of the car anyway.
You mentioned a wire is going somewhere, did you figure out where does it go? Does the wire go to the rear door, close to tail light?
Actually I want to know, how did you connect camera with the aux video input in COMAND? Did you route a seperate wire or use wireless camera?
Thanks.
First the cheap ebay cam, did a great job but in the past 6 months, the image started getting flaky. (note that I did have it connected to permanent power)
Now I am on the scout to replace it with a better camera. Preferably something more factory fitting. (without modification, since the last one was for an S-class but needed shaving down to fit it in)
Does anyone know if the ML W164 would use the same camera?
http://www.ebay.com.au/itm/281078993291?
This one is only CMOS not CCD.
http://www.ebay.com.au/itm/2008-Merc.../130897963982?
- First pic shows the square/micro camera position relative to the rear license plate.
- Second pic shows the closed-in camera itself.
- Third pic shows the COMAND view picking up a kid's bike 4ft behind the bumper, which the rear view mirror couldnt picked up. Note the low angle and the rear bumper reference always shown.
Hope these help!
and choise what camera you use and you can use wire or buy wireless module''i use them on my car''
i use signal from reversing light to flick picture when in reversing mode,but it's crap when you start car,but if you use this signal and relay with other power supplier this problem will be solved.
