R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Lower my R500 with H&R spring
Old Apr 14, 2008 | 06:48 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Originally Posted by XRX
When I received my H&R package, it only come with 2 front springs then I found out all the R come with air suspension from the rear. You may check any R in NA, there are no springs at the rear, just airbags.
NIIIICE!! Wish mine was like that
Old Apr 15, 2008 | 02:51 AM
XRX's Avatar
XRX
2006 R500, 2002 996TT
Originally Posted by DonMario2k
it's probably the renntech lowering module i assume.
where do you get these numbers from?
http://www.renntechmercedes.com/w251_pricelist.pdf
Old Apr 15, 2008 | 09:54 AM
ROCK-A-HULA's Avatar
Bmw, MB
Old Apr 15, 2008 | 10:25 AM
Benz-O-Rama's Avatar
Question:
Did you do an alignment after the lowering? If so, were they able to adjust for all of the negative camber you're creating at that height? The reason I ask is on my lowered E500, I'm chewing through tires every 10K miles or so because of uneven wear. The W211 cars just don't have enough adjustablility (<---Made up word ) to allow for the negative camber created when you lower it.
I'm wondering if the R-Class has the same problem. I talked to the service manager at my dealer and he said that I shouldn't lower it because of possible alignment issues. He could've just been saying that to try to prevent me from doing it, but all of the W211's that are lowered have this problem.
That said, I'll probably lower my R500 anyway. Yours looks great but I wonder what the consequences are going to be down the road.
Old Apr 15, 2008 | 12:20 PM
XRX's Avatar
XRX
Originally Posted by Benz-O-Rama
Question:
I only drove it 2 days after its been lower before dropping it off the body shop. I will do the alignment when i get back my car and keep you update.
About the consequences of lower, if you wife is the main driver and I'm sure she will prefer the stock ride. H&R firm up the car especially with my 22". For me I love it, it never feels like a van again. But don't quota me, I used to have coilover suspension on almost every cars I have, so I get used to firm and lowered cars. Other than that, it look 100x better
Old Apr 15, 2008 | 02:27 PM
I've got the full airmatic system.
If I lower it, I can use links from adustableairride.com for about 275.00 total.
Keep us updated on the alignment. I'm interested to see what MB says about that.
Old Apr 15, 2008 | 03:09 PM
  #32
XRX's Avatar
XRX
Yes, If you have full aitmatic, you can buy the linkage kit from John. He told me I can have half kit to lower my rear. The H&R firm up the fronts, but I feel the rear lowered with Star Diagnostics are the same, if not firmer than the front. Maybe I've set the ride height with only 2 finger gap left. If you're not going to slammed like mine, I'm sure it will be much softer.
Old Apr 15, 2008 | 03:44 PM
  #33
MBNorway's Avatar
500 SL R129 and R 320 CDI W251
......or you can adjust on the stock airmatic arms. But it's not easy to get it eaven.....
Old Apr 15, 2008 | 08:23 PM
  #34
dynomite05's Avatar
04 CLK 320 > CLK32K
Your rims are niCE!! I just ordered those myself for my w209. Are yours hyper silver or chrome?
Old Apr 15, 2008 | 08:51 PM
  #35
Oh, the MRR's? They're hypersilver but I just sold them 2 months ago and ordered a set of Sevas Forged R55's, custom 3pc.
Old Apr 15, 2008 | 09:00 PM
  #36
dynomite05's Avatar
04 CLK 320 > CLK32K
Great choice!! Hope to see some pics!
Old Apr 8, 2009 | 12:59 AM
  #37
nanoera's Avatar
2011 S65
Can anyone tell me whether it's necessary to remove the upper front strut assemblies to swap in H&R? Can I get away with only removing shock absorber? Thanks.
Old Apr 10, 2009 | 11:05 PM
  #38
nanoera's Avatar
2011 S65
Had the springs installed today. Took 6 1/2 hours in a independent shop. The whole strut assembly needs to go off.
I then tweak the rear right height using Star. The height from lower wheel lip to fender is:
Front 23 3/8"
Rear 23 1/2"
There are left/right rear inclination angles that need to be measured and entered once manual rear height is set. However I don't have the tool to measure, so I put in the same existing numbers in control unit.
A short test drive impression is flat cornering and still cushioned ride over pot holes. The whole car feels more nimble in turns and the ride quality is just tight enough for my taste and kids' comfort.
Tomorrow I'll get the wheels aligned and all should be fine.
Old May 9, 2009 | 03:44 AM
  #39
559EVO's Avatar
2005 C55
Any pics?
Old May 9, 2009 | 03:44 PM
  #40
nanoera's Avatar
2011 S65
Here you go
Old May 9, 2009 | 04:01 PM
  #41
adr4's Avatar
R Class
Ouch!!!
Yo, that is sick!!! I just got my R500 looking into 22" first then I will probably lower depending on how it looks with the 22". I love the Fog Lights. I have seen some other threads on this but did you do it yourself?
Old May 10, 2009 | 12:55 PM
  #42
nanoera's Avatar
2011 S65
Yes. The fogs are DIY too. From a helpful thread contributed by member Rosswell, Heron25, and others.
If you are going with 22", I am 99% surer you'll need to drop it. Look again at XRX's before and after shots with his big wheels and you'll know why.
Old Jun 7, 2009 | 11:40 AM
  #43
Tork Monster's Avatar
Chrysler 300C SRT8
I loove this shot of your car, but couln't find it here, so...
