R-Class Oil Change Instructions
oil plug location
Hi here is a shot of R350 oil plug if anyone is interested. There's about ten small 10mm hex head screws that hold the plastic cover on under the car very easy job.
I prefer the gravity method as well. The panel can be a bit of a pain to remove, but once that's off the rest of the job goes quite smoothly. Oh, btw, the oil drain plug is 13mm in size.
#35
R350 Oil
I plan to do my oil change myself too. Does the R350 also take 10w-40 oil? Also, has anyone had experiences in doing all the Service A and B by yourself instead of taking it to the dealership? Do you get charged at the end of the lease by not having it done at a dealership?
#39
Others from sheet 229.3 include Mobil 1 5W-40, Mobil 1 5W-50, Mobil SHC Formula MB 5W-30, and Mobil Special X 5W-40.
The beauty of Sheet 229.5 is that: 1. It's a shorter list; 2. It only lists 3 Exxon Mobil oils, one being Mobil 1 0W 40; 3. You can go longer between changes...if memory serves MB says up to 15,000 kilometres.
By the way Sheet 325 contains all the coolant choices - - even harder to find - Just buy it from MB and you're good to go - mix it with distilled water though 50:50 if it's not pre-mixed. Always handy to have a jug around.
Looks like 0W-40, 5W-40 and 5W-50 are approved for all temperatures, but 0W-30 or 5W-30 is ok for colder climates too.
Where is this 229.5 sheet that everyone (and the booklet) refers too?
Thanks!
