Where is the rear fuse block?
I have looked inside the cover of the rear trunk on the passenger side but could not locate the rear fuse block.
Anyone knows the exact location of the rear fuse block?
Thanks in advance,
Thanks in advance,
2006 R500 Red w/Tan interior
It is in the spare tire well on the passenger side. There is a carpet/cover over it, that you have to remove to get to it. Remove spare tire and that should help you out. Then remove the cover in the well on the right side, Rear SAM is located there, it is clipped in the up position, on big clip on each side holds it up -- if I am remembering correctly.
