R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Radar Detector Hardwire
Old May 18, 2009 | 02:22 PM
rdrracing's Avatar
R350
Ran my passport radar detector hardwire to the passenger fuse box to hardwire and cant find a positive lead that isnt controlled by the ignition, any suggestions? The fuses seem to always have power?
I couldnt find a good positive lead in the overhead light cluster/sunroof controls either. Either place would be great. Thanks
Old May 18, 2009 | 04:54 PM
silverspecial's Avatar
2007 R350 - P01- Black on Black, 2008 Toyota Sienna Limited
12V lighter plug in the center console is the only one any of us has used up front. I like you went to the passenger side fusebox as I didn't feel like taking apart the console to get to the plug
Old May 18, 2009 | 05:45 PM
AsianR350's Avatar
08 R350, 12 Mercedes R350
You have 2 choices:
Take the center console apart and splice the wire directly to the cigarette plug.
OR
Run the wire to the rear trunk fuse block and buy a splice fuse block from any Auto Part store to plug in the fuse block. (I think it is 15Amp fuse number 46)
Old May 20, 2009 | 12:40 PM
davidbho's Avatar
X166, 997
did you notice if your car has the IR glass?
Just fyi...when i put my radar detector on the winshield, I realized it wasnt working for ****...untill i put it into the 2 spots where there was no IR coating. Then it worked.
