At the risk of sounding stupid...
2008 R350, '67 GTO Convert, 2008 3500 RAM, '54 Packard Clipper, '37 Chev Grand Master Deluxe
Can DVD's be viewed using the "DVD Navigation" slot?
2007 R350 with Nav and 6 CD changer.
2004 S55 (SOLD, miss it every day), 2009 GL550
the answer should be in your manuals, but no, you can't.
unless i'm wrong.
however, since I don't have your manuals, I need you to check for me.
post back when you do, thanks.
unless i'm wrong.
Well, that s*cks!
Swap a 2009/2010 Nav system into a 2007?
If you have the 2009 + R class you can buy this module and watch dvd's on the command and stream video to it from an outside source. However for 2006,2007,2008 - from what i understand they do not have the built in dvd decoding in the command system so it won't work with these model years.
https://mbworld.org/forums/r-class-w...l-r-class.html
I am not sure but the guys at mid city know a lot about this stuff... i would recommend you call them - if you do get the dvd's to play on your 2007 r class let me know. I want to do the same myself.
312.421.1114 sales@midcityengineering.com
-j
-j
Anyone know something on this???
Seems a little silly that it reads DVD nav discs and not DVD's.
Something in the programming?
I am not an expert by far...but I am certain it is in the type of data nav info is encoded in vs. a typical DVD movie. The Nav system processor is not programmed to decode the movie formats. The only reason it is a DVD reader is likely because a DVD disc has a large capacity. My 2000 W163 used CD maps, and it was 10 regional discs to cover all of North America. Now that NAV reader could play music CDs too.
