R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Message Light
Old Aug 30, 2010 | 12:23 PM
shobbs666's Avatar
2006 R350
Message Light
I have a 2006 R350. every once and awhile I get a message light for "light out back right (Substitute Bulb on)", then another one for left, (Substitute Bulb on), Sometimes I get all the above but this time it says that the license blub right out ,then one for a "Tall Light", whatever that is. But all back Blubs are on. I Reset and for weeks "No Message" at all about a problem with the Back array. This usually happens when my wife drives the car. Then when I go out to restart the car to see what's wrong no messages everythings OK!! I did purchase the 4 year, 50,000 MB warranty when I purchased the pre-owned R. You know how the Dealers are "It wouldn't happened while it was here, we can't find anything wrong". Any ideas?
Old Aug 30, 2010 | 03:51 PM
avlis's Avatar
2008 VW GTI
Replace the bulb. Even if it isn't burnt out, it could be creating enough resistance to trigger the warning. I had this happen to license plate lights on my old C-Class. I'd get out and check only to find both bulbs lit. Replacing the bulb anyway fixed the warning.
Old Sep 8, 2010 | 08:49 PM
R. Reyes's Avatar
R350 4-matic
More than likely it's the wiring harness/connector(s). Mine had same problem to an extent, then it just started burning out bulbs, one right after the other within hours of replacing. Took it to dealer, they said it was a harness/connector issue. Replaced entire harness, w/ new updated one (there should be a TSB from what i gathered), in 1 day. Have not had a problem in the 15 months since.
Old Sep 14, 2010 | 10:04 PM
Ted Flynn's Avatar
2011 R350 BlueTec
Yep, same here.
Intermittent issues and just got bad bulbs. Changed them out and all the issues went away.
