2008 R350 Third Brake Light Lens Removal
Thanks!
You can order from MB.
Get service DVD here: http://www.startekinfo.com/StarTek/o...tedDocId=11498
If one or more of your LEDs inside the housing are not working, one of the resistor is burned or opened.
To able to remove the len to replace bad resistor, use hair dryer to heat up around the housing of the len. I had fixed a few third brake lights on other cars and it worked (replaced bad resistor to restore the LED light)
After much thought, the only way to successfully remove the "High Mounted Brake Light" was to actually to break off the red lens, and then using a small flat blade, depress the spring clips which allowed for the entire housing to come out. There was no way, to unscrew the torx screw in such a confined space, let alone not letting it or the spring clip fall into the door hatch hollow.
Please find video
I hope this could help
https://www.alldatadiy.com/buy/
i find it is quite good. I also have the Starteck system but it is much harder to use.
