R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
'06 350 Bad Reverse Light
Old Dec 16, 2011 | 08:43 AM
Mrmarcusw's Avatar
R350
Question '06 R350 Bad Reverse Light
My wife's passenger side reverse light will not come one. I have replaced the bulb and even swapped it with the back up bulb. Is still will not come on. Have anyone else had this problem?
Old Dec 16, 2011 | 01:51 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
check the contact points on the socket if it is clean then check the base plate it mounts on to. this has been a problem for pretty much all my mb cars, corrosion build up on the contact point. all you have to do is scuff it up with some sand paper (fine) GL
if u still have the warranty have them change the whole plate, I've done this to my ML before i found out it was just a contact point issue.
Old Dec 16, 2011 | 03:56 PM
Mrmarcusw's Avatar
R350
Thanks. I'll give it a try and let you know what happens.
