My R350 Airmatic is stuck in Sport mode. The Airmatic works fine, goes up and down, you get the air dump when parked and getting out, the air pump works fine and adjusts the level correctly. When I start it after a second the Sport suspension light comes on. If I push the suspension button I can get it to go to Comfort for a second right after starting but it resets itself to Sport. I've checked the connections, fuses and no codes only the Airmatic "Visit Workshop" The rough ride is killing me.
If you have gone through it and checked for the obvious I would call either a dealer or independent that specializes in Mercedes. You need someone with a Starscan system to look into the module itself and determine why it is locked in one setting. I have a pretty good home scan tool installed in an old laptop and it doesn't go that deep.
