R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Bad ABS sensor
Old Oct 1, 2015 | 03:44 PM
marc hanna's Avatar
2023 GLK250, 1987 560SL
Bad ABS sensor
Just replaced a bad driver side ABS sensor. The plastic cable clamp had broken and it was rubbing against the axle. It was a 5 minute job, I didn't even take the wheel off - just cranked the steering wheel all the way to the left and had plenty of room. I used a tie-wrap to compensate for the broken clamp.
Old Oct 1, 2015 | 04:10 PM
user 823908234's Avatar
Was it a fail? What tipped you off? CEL? Or did you just happen to be rolling around on the garage floor under the car?
Old Oct 1, 2015 | 04:14 PM
marc hanna's Avatar
Yes a complete fail. The wire inside was completely worn through. I started intermittently getting ABS and ESP error lights on the dash, and then they stayed permanently. No CEL though. I looked inside the wheel well and could see that the wire was damaged.
