Brake tools?
I have read various thread with brakes. I have a 2008 r350 gas with 330 front and solid rear.
I have many sizes of allen keys and metric and english sockets. I am not sure what I have for torx or star whichever its called.
Can someone give me a breakdown of the sizes and tools needed for this? Including the set screw in the front rotor.
I will also be opening the brake line to allow the fluid to drain out and replace the fluid (not sure if thats bleeding or flushing but thats what i will do). What tool for that too?
I just dont want to jack it up, pull the wheel and not have the right tool. I am buying the star/torx stuff as I go knowing that mb likes it.
Standard Metric tools are basically all you will need. I don't know what size the rotor set screw is since I never did have to change the OEM rotors that went on it at 46k. Now do make sure you have a 9MM allen key or socket. Those are very hard to come by believe it or not. I found a Oreily's that had one stashed in the back. Other than that normal metric stuff like wrenches and sockets. A big screwdriver and clamp for compressing the brake piston.
Don't do that if you don't know how to properly bleed brakes. You run a risk of introducing air into the line and that is WAY worse than old fluid remaining in the line. Strongly advise a brake fluid flush. I used a Power Bleeder to flush her brakes a week or so after doing the pad install but a shop can do it for you as well. I have never expelled fluid out of the bleeder when compressing brakes and would be really concerned that air would get in.
It was a simple job, once I had the freakin' 9MM allen.
down the road you should look at one of these.
http://www.motiveproducts.com/collec...r-bleeder-kits
It is $49.50 on Amazon... I used it on the R to flush the brake fluid... It was cake... the hardest thing was jacking up the car and pulling wheels... It works at a low enough pressure that you don't have to worry about blowing a seal but also don't have to screw around with those crappy vacuum pump bleeders either.
Also the brake fluid at mb was only 16.
Fronts are done gonna do the rear in a bit, but so far a very easy task. The only issue, other then the 9mm, is the rotor removal. I hate the first time I do things in the sense that I am not sure what to expect. So the set screw comes out with my impact drill. First time I wasnt aware I needed to remove the caliper holder. The other metal thing held on with 21mm bolts. Which was only a minor inconvenience that I dont remember being documented before. That wasnt the issue. If the set screw is there only to help get the rotor lines up before install then great, but after I removed the screw I figured tap, tap and bam the rotor would drop off. Well tap tap tap tap baangbang bang and still on tight. Spray with liquid wrench and wait before ta
Tap, bang bang and nothing. More spray and more tap and still nothing. Am I missing something, forget something, is it seized or melted together? Well after a while I gues the liquid wrench worked because tap and poof. Thats when I couldnt get it off without taking the other bracket.
So front driver took 6 hours and the left 30 minutes, but that included the bleeding and tire removal and replacing, jacking and such.
Also if you remove the calipers, you need new self locking bolts from your dealer.... to do this by the book... Yet I have been changing rotors for years on my MBs and never replaced them. No calipers falling off yet.
