R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Brake Moly Lube?
Old Jun 10, 2017 | 06:07 AM
Good Stuff's Avatar
2008 R350 and 2012 E350
Brake Moly Lube?
Does Mercedes say not to use any sort of Moly Lube on brake components? I'm about to replace my pads.
Old Jun 12, 2017 | 11:39 PM
efzauner's Avatar
2005 C240 2011 R350
no, they say to use only MB lube!
You dont need much. some on the caliper pins and on the shoes where they slide in the stainless steel guides. And the pin that holds the shoes. it rust easy and is hard to remove.. atleast up here in canada where there is lots of salt on the roads.
I used quality silicone brake lube
