R350 Ride Quality Question
The other day I swapped on a set of 20" AMG rims from a 2011 r350. They had a set of 6/32 set of Pirelli Scorpion Zero summer tires (265/45r20) also running at 38-40 psi.
My problem is the ride quality (something very important to me on my R) right after the swap has deteriorated noticeably. I feel so much more of the road now and am pretty disappointed. My wife says the change is like going from a comfortable sneaker to hot stiletto shoe. they look hot, but they aren't near anywhere as comfortable.
Comparing the two tire sized on tiresize.com the 255/50r19's are 29" diameter, 5" sidewall, and 10" wide.
The 265/45r20's are 29.4" diameter, 4.7" sidewall, and 10.4" wide
So my question for you guys is this. Should loosing 3/10's of an inch in sidewall height make that much difference in ride quality? Is part of this problem caused by changing the brand and season rating? Short of going back to the 19" setup, can you suggest any iseas to improve the ride quality, maybe trying to find a taller 20" tire size?
While I can, I really don't want to go back to the 19" rims. Any ideas would sure be helpful. Thanks in advance.
It would be pretty safe to say the 20" tires are older than the 19's. How much older I couldn't say. But that summer tires have a stiffer side wall than all-season, that I didn't know.
I also read in another thread:
One thing for sure. I'd really like the 20" wheels to stay. I was thinking to go with a replacement tire having a taller sidewall (say a 265/50r20 that has a 5.2" sidewall). It's not a lot, just another .5 in sidewall height over the stock 20" tire.
But considering how much difference between the difference between the 255/50r19 sidewall of 5", and the 265/45r20 sidewall at 4.7, clearly the R is sensitive to these small changes.
Only thing is I'd have to remember that when my speedo is reading 75mph, I'm really going 78. Any thoughts on that?
