Request for part # lookup
VIN: 4JGCB65E26A027469
1. Replacing front and rear brake pads and rotors. I understand the caliper bolts (4 per axle) should be replaced but can't find part numbers. Also I'm unclear whether the guide pins should also be replaced, but if so would appreciate those part numbers also.
2. Replacing steering pump. Looking for part number to order genuine steering gear oil. I found a bulletin from August 2011 with the following numbers/codes for the fluid I need:
A 001 989 88 03 10
BQ 146 001
Sheet 236.3 Specification for Operating Fluids BB00.40-P-0236-03A
3. Genuine MB brake fluid DOT 4+
Thank you!
guide pins. have not found them aftermaket outside of a remanufactured calipers.. so dealer again. important to change these things rust bad...
here is your handy dandy fluid lookup site.. https://bevo.mercedes-benz.com/bevolisten/236.3_en.html
as for brake fluid. its 331.0 you can use the above link to find out that there are no other approved fluids. so dealer. every 2 years for your flush!
Have fun!
