Reset brake wear warning on c350 2014
Unclear if the check break wear was on before you cleaned them? Immediately after?
Either you broke the sensor, or missconnected it or just coincidentally the pads where just about to hit the sensor.
You can check the continuity of the sensor with a DMM/ohmmeter. Should be shorted. a small wire gets worn to open when the pads wear.
I find that the sensor goes off way to early, often with 3/16 pad left so I cut the wires and soldered them together so they dont trip the warning again.
it is very easy to check break wear visually from between the wheel spokes. I also change summer/winter wheels so I can inspect twice a year. and note the wear.
