SRS light : DTC 9013
So i finally got my iCarSoft MB II and got a chance to read the code for my airbag. It is DTC 9013 which says:
"The component or the signal line to the component S68/1 (Seat belt buckle and seat belt warning switch, driver) has open circuit or Resistance too large." DTC status is current and stored.
Does this mean replacing the seat belt buckle will fix this or could it be something else?
Thanks!
Thanks!
I went through this exact issue
Also getting code 9013 on my Gl320cdi. The SRS light does goes off after a while, but it keeps displaying the SRS disabled msg fron front right side. However, both front seat belts seem to work fine as the buzzer goes on for each if you disconnect left and right seat buckles while driving.
How do I get rid of the SRS alarm message when you switch the vehicle on?
