R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
blind spot assist
Old Dec 29, 2017 | 03:36 PM
healthyoptions's Avatar
r 350
blind spot assist
i have a 2011 r350. according to the manual blind spot assist is available. it does not come up in my menu as it is now established. to get to it do i have to go to the reset factory options? if so will i automatically loose all the things that are already there by default. i was not the one to set this up. i believe the dealer did. if i follow the instructions that i have attached will the blind spot assist come up under vehicle?
thanks
are these the instructions to follow to turn it on? what should i watch for to not erase what is already set and functional?
Old Jan 1, 2018 | 04:59 PM
SndsoftheSbrbs's Avatar
2019 Audi Q8, 2015 GL63, & 2005 E500W4
Just because something is in the manual does not mean that it is an installed option on your particular vehicle. I can't believe that it would ever be turned off. My R350 BlueTEC has it installed, but my vehicle was a custom build. Blind Spot Assist was a very rare option in R-Classes sold in North America. If Blind Spot Assist is installed on your vehicle, you should be able to see a triangle in the corner of each of your mirrors. At slow speeds, they should be constantly illuminated in a yellow-orange color. At higher speeds, they should disappear. When a vehicle is in your so-called blind spot, you should see a red triangle in the side-mirror on that particular side.
Old Jan 7, 2018 | 06:47 PM
efzauner's Avatar
2005 C240 2011 R350
wow! you can turn it off? Good news for me as mine is broken and always tells me it is inoperative. I dont want to spend $1000 to fix it
