struggles to start & battery posts getting hot
Could this be a starter issue, or just simply a loose connection or wire somewhere.
Not long before this, I had the taillights burn out and a passenger side low beam. Might be unrelated, but in these cars I never know.
Anyone have any similar experience?
I have had a shorted alternator on a car that had exactly the same symptoms..
You could boost it with another car, it would start but as soon as you disconnected it stalled. Booster wires getting very hot.
easy to diagnose anyway.. OP should just check his wiring and even remove the alternator + cable to see if it fixes the problem.
I personally looked at all the wiring under the car I could find, and I had all the carpeting and flooring out and followed the main positive cable from battery, to under the hood, then down to the alternator and starter. All connections tight and no frayed wiring. Hopefully it is true starter. The vehicle has 473,000km on it (like 290,000+ miles, and probably originally starter)
so here is hoping. Thank you for the replies, I'll keep the thread active with results
If you look at battery alternator starter circuit, there are not many ways you can get such power drain without lots of sparks.
If the starter is shorted it would not turn and your power drain would only occur when you crank.
The solenoid drive circuit is low amperage.
The alternator is the only place where catastrophic failure of the diodes, or perhaps the stator winding can short to ground.
I am having the starter changed at the same time while in there, but it starts fine with the alternator removed, so definitely alternator was toast.
Thank you for your input and replies, it has been much appreciated!!
