Battery bad after 2 years only
Bought a new battery 2 years ago, left the car untouched for 11 months as I was abroad. When I came back, the battery was totally dead, so I charged it for many days. It works but the dashboard shows the battery sign, and it sounds weak when I crank. Is it normal and is there any way to make that battery good again?
My original battery had to be replaced after 10 years in service, and I decided to buy an OE replacement (@ $167 MBZ dealer)... I changed it Dec 2016 and haven’t had any issues. I’m very happy w/OE but are sure there are cheaper aftermarket options you can chose from.
My 2005 C240 battery was still good after like 12 years.
I was having electrical issues with my 2011 R350 so I put in a new AGM from our local Canadian Tire, cost about C$200 and put the R battery into the C. All same size.
Ended up being the alternator. These batteries do last a long time.
I was lucky enough to get it working to drive it to my fav garage 50 km away in Montreal.
It was the regulator, overvoltage the mechanic said. Got all sorts of error messages from cannot shift transmission to SRS failure to ABS failure etc. Seeems various modules just shut off when they see bad voltage.
