Aftermarket command unit
I was told that to change the command unit you need to purchase some box thing because of the fibre optic cables.
Has anyone changed there unit?
was the fibre optic cables an issue?
thanks
You can have a look at Aliexpress. Have been digging the forums for so long that I am sure now that these units are all the same but change the logo.
Android 8, octacore, 4GB RAM, 32 ROM with a special box for optical lenses and for canbus.
Completely transformed the dash of the R. I included the Carplay module to it and it's perfect. It's compatible to all the functions of a new technology robust 2019 Vehicle.
I also purchased the carplay module which works perfectly.
1. how long does it take to boot up?
2. did you have the original NAV and if you did, were you able to use the original GPS antenna?
3. hows glare on the screen during the day?
4. are you still able to set the time (clock in instrument cluster) through this unit ?
Jon
Jon
2. I did have navigation and yes I used the OEM GPS Antenna. I purchased an adapter wire for $9 to connect from OEM to Aftermarket radio.
( Also purchased an adapter for the rearview camera (
3. Glare is minimal; no worst than OEM unit. I set the brightness to maximum. Plus all my windows are tinted to 20%.
4. You can not control the clock on the dash. It remains set with the time you had when the OEM unit was removed. Personally not a issue for me. Unless you have OCD when the time changes for daylight savings time. If it bothers me too much then I will plug the old unit twice a year. (20 minutes of my time yearly). LOL
Steering wheel buttons work fine. Mine has the Harman Kardon fiber optic system. Got one of these and everything works perfectly except front to rear fade:
1) Do you still use the DVD player located in the front centre arm rest to play video for the rear?
2) Is the Audio playback over the car speakers or u still need headphones for the rear?
3) Does it make any difference if my Command comes with TV Tuner?
4) Any shortcomings since you have had it for a while now?
Thank you very much in advance and thanks for sharing. Cheer and stay safe
(https://www.amazon.com/gp/product/B0...ie=UTF8&psc=1)
Also purchased an adapter for the rearview camera (https://www.amazon.com/RF-design-Pig...ronics&sr=1-3)
